Old 08-10-2004, 04:57 PM   #1
bigbird
bigbird is on a distinguished road
bigbird's Avatar
Default Auto trans "muck" question
Anyone who's changed an auto trans filter on a 1.9 has seen the fine metal particles on the ring magnet that look like mud. My question is, since the 1.9 auto doesn't have bands, what wears in the auto trans to produce this "muck"?
bigbird is offline
Old 08-10-2004, 05:14 PM   #2
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
1997 SC1
Default
First of all, bands are friction material (like a brake shoe) using a resin impregnated paper bonded to a metal substrate. The S-Sat uses no bands but has clutch plates which are made similarly - friction material bonded to metal.
Either way the clutch material that wears off is non metallic and won't wind up on your magnet.
What you do find on the magnet are misc metal wear particles that were either built in at assembly or abrade off some part inside the trans during operation.
A small amount of this is quite normal.
Bill Murray is offline
Old 08-10-2004, 07:51 PM   #3
wolfman
wolfman's Avatar
Default
What he said^. That fine "fur" of metal on the magnet is both typical and NORMAL. Just wipe it off as best you can and reuse the magnet.
wolfman is offline
97 SL1 Auto trans w/no "REVERSE" bigpoppaski S-Series Tech 7 07-07-2007 02:15 AM
97 SL1 Auto trans w/no "REVERSE" bigpoppaski L-Series Tech 1 07-02-2007 12:14 PM
2000 SL1 w/ Auto Trans - "Noise" and White Smoke jonsoini S-Series General 0 05-11-2005 11:58 AM
'02 auto trans "weirdness" analog S-Series Tech 11 11-12-2002 04:26 PM
"2001 SL2" Auto. Trans. ? danielwau S-Series Tech 2 01-18-2001 11:22 PM
