Old 10-31-2014, 02:39 PM   #1
Daniel9
Daniel9 is on a distinguished road
2004 ION-2 Sedan
Default Crazy Electrical Problems!
All of a sudden my 2004 Ion 2 stereo wouldn't play unless I opened the driver's door and closed it a second time. Then, the front passenger window quit working, then the back passenger window quit working. The other day I was checking the back passenger window and it started going down and the stereo turned on too! I know it's Halloween today, but any ideas what's going on?
Daniel9 is offline   Reply With Quote
Old 10-31-2014, 05:09 PM   #2
Default Re: Crazy Electrical Problems!
Examine the general wiring harnesses for these parts and you might see something in common otherwise this may be a needle-in-a-haystack chase to find loose connections. Grounds too.
Old 10-31-2014, 05:21 PM   #3
ruley73
ruley73's Avatar
I recommend that you inspect the wires in the driver door jamb. I'm thinking there are some frayed wires inside that rubber covering.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 203K miles
2018 Chrysler Pacifica Touring L 68K miles
Old 11-03-2014, 02:21 PM   #4
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
also check for bent/dirty pins in the driver door jamb too. if those controls are not plugged in, then none of the doors work.
03 ion-2 Sedan 5sp
♕KCCO
2001 L200 electrical going crazy warelephent L-Series Tech 2 09-14-2012 03:15 PM
Electrical issue driving me crazy!!!! Krazykeep S-Series Tech 9 02-08-2012 02:15 AM
transmission/electrical issue, driving me crazy! fullyloadedSL2 S-Series Tech 14 01-14-2011 12:01 PM
help! crazy electrical problem slosaturn S-Series Tech 6 09-04-2006 09:11 AM
Crazy Electrical Problem myoung Miscellaneous Tech 3 03-12-2003 08:35 AM
