Old 06-11-2008, 10:49 AM   #1
gregaroo329
gregaroo329 is on a distinguished road
Default Rear defroster, door chimes quit working
I have a 96 SC2. Recently, the rear defroster and door chimes stopped working (including the headlights chime).
All fuses seem to be fine. Anybody else had this problem?
After checking the fuses, I am at a loss as to where to check next. Any suggestions?
gregaroo329 is offline   Reply With Quote
Old 06-11-2008, 12:08 PM   #2
Default Re: Rear defroster, door chimes quit working
CHIME module. Deck-of-cards-sized gizmo plugged into the BACK side of the interior fuse box. I'll bet your interior light doesn't come on with the door open either.
Remove the kick panel on the driver's side, and you'll see it; it's typically orange, green, or sometimes white. First thing to try is to simply unplug it and plug it back in. If that fails, you'll probably have to replace it. Salvage yard part should do; the color of the box doesn't signify anything.
Old 06-11-2008, 12:38 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
And red.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Rear Defroster not working. Defroster button does not light up. Spartus S-Series General 35 01-29-2012 07:18 PM
Rear & Mirror Defroster Quit Working! JButler1983 L-Series Tech 2 01-09-2008 08:27 PM
Rear Defroster Stopped working. brianteel S-Series Tech 3 12-28-2007 10:51 AM
Rear window defroster quit snydley S-Series Tech 5 03-27-2005 10:44 PM
Rear Defroster Not Working in 99SC1? sandybright S-Series Tech 12 01-30-2004 10:17 AM
