Old 11-27-2020, 11:05 AM   #1
Nirbapow
Nirbapow is on a distinguished road
Default 2007 ion overheating
I have a 2007 ion with the 2.6ltr motor. It has a problem with overheating with stop and go driving or simply idling. The fan only comes on when the ac compressor kicks on. I have tested the fuses and disconnected the temp sensor and the fan still doesn't come on.
Any suggestions on where to look next for a solution?
thanks in advance
Nirbapow is offline   Reply With Quote
Old 11-29-2020, 06:56 PM   #2
ruley73
ruley73's Avatar
Default Re: 2007 ion overheating
A lot of unanswered questions...
Which engine does your car have? A 2.6L wasn't an option for the Ion.
How do you know the engine is actually overheating?
What does the temp gauge say?
Are you losing coolant? If so, where is it leaking?
What coolant/water ratio are you using? 50/50 is recommended, but up to 70/30 can be used. Water alone will boil prematurely.
The radiator fan normally doesn't turn on until the temp gauge is a little past the half mark. If you just have some coolant boiling out of the reservoir, you should try replacing the coolant lid. Coolant will boil prematurely if the cap isn't holding pressure.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 205K miles
2018 Chrysler Pacifica Touring L 74K miles
Old 11-30-2020, 11:51 AM   #3
Bill Murray
Bill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the roughBill Murray is a jewel in the rough
2007 ION-2 Quad Coupe
1997 SC1
Cheap laser heat thermometer (some now as low as 10 bucks) is great for diagnosing this stuff.
Old 12-03-2020, 12:39 PM   #4
Nirbapow
Thanks Murray for your input.
Old 12-04-2020, 10:54 AM   #5
Bill Murray
1997 SC1
You can check your friends and neighbors for COVID fever too!
Old 12-10-2020, 12:11 PM   #6
Nirbapow
I just loved to do so..
2007 Aura XE Overheating msbug Aura General 1 04-10-2015 05:46 PM
Vue Leads Equinox in 2007 Sales as of 7-1-2007 mikec Vue General 2 07-06-2007 06:52 PM
Vue Leads Equinox in 2007 Sales as of 2-28-2007 mikec Vue General 6 03-13-2007 04:42 PM
MT Fluid Usage In 2007 And Prior MTs And TCs (02/05/2007) asdf S-Series Tech 0 02-16-2007 02:55 AM
2007 Aura XR vs 2007 2.0T passat sedan, which to buy? fantarain Aura General 43 11-26-2006 12:39 PM
