Old 10-16-2009, 10:13 PM   #1
BRIAN41920
BRIAN41920 is on a distinguished road
Default Do newer SOHC heads have the same problem with cracking as the 1994-1999 SOHC heads?
I have a 2001 SC1 with the 1.9 SOHC engine. I am 90% sure I have a head gasket going. My only question is: Do the heads on my year vehicle have the same problem with cracking as the 1994-1999 heads on the SOHC engines? I was just wondering....
-Brian
BRIAN41920 is offline   Reply With Quote
Old 10-16-2009, 11:02 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: Do newer SOHC heads have the same problem with cracking as the 1994-1999 SOHC hea
dude, you didn't need to make two identical threads on the same subject (even though you re-worded the thread titles)...
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 10-20-2009, 07:46 PM   #3
BRIAN41920
Thank you for the answer...... i will never post a thread to fix a mistake in my title ever again oh god of the saturns..........my deepest apologies
Old 10-20-2009, 09:15 PM   #4
sidney004
sidney004 has a spectacular aura aboutsidney004 has a spectacular aura about
Its a good question, I am curious to know the answer as well.
2000 SL with 114,000
sidney004 is offline   Reply With Quote
Old 10-21-2009, 09:38 AM   #5
I don't think there is any known or confirmed pattern to the SOHC head cracking.
Best theory I've seen so far is OldNuc's that some people running 50/50 coolant develop hot spots and boil over in the head. That would explain the seemingly random occurrences - some people would run 50/50, others run a higher antifreeze concentration.
Old 10-21-2009, 09:47 AM   #6
ezzieyguywuf
ezzieyguywuf is on a distinguished road
As a former machinist (I guess apprentice ;--)) I can tell you from my, but more importantly my co-worker's (who have been working on cylinder heads much longer than I have) experience that there is indeed a pattern with SOHC saturn heads cracking. I couldn't tell you about the new one's (sorry), but I can say that the first thing they asked me when I told them my gf bought me a Saturn for christmas was "Is it DOHC or SOHC". In the 3 years that I worked at the shop, I personally found about 3 cracked SOHC, but 0 cracked DOHC.
ezzieyguywuf is offline   Reply With Quote
Old 10-21-2009, 10:46 AM   #7
I meant a pattern so far as years/miles.
It doesn't seem to be restricted to a particular year or generation, which might point to a defect in manufacture or material. We do know that SOHCs experience head cracking is enough to take notice, but that it's very rare for the DOHCs
If you or your coworker saw a particular pattern in the SOHC (particular years, at a certain age like the radiators, or at a certain mile range), that would add to the S-series body of knowledge.
Old 10-21-2009, 03:27 PM   #8
ezzieyguywuf
Yea I'll go by the shop and see what they know. We don't get a lot of newer model one's in, but that could just be because they don't have enough miles on them yet for people to overheat them :-)
I should stress that these things tend to crack when they overheat, not on their own, so if you take care of your car and keep an eye on your gauges you should be able to prevent this failure.
I don't know how many generations this cylinder head design has gone through, but whatever was out in the '90s is what we say a lot of (just off the top of my head). They don't tend to make any changes to things like the cylinder head design on a year-to-year basis so any comparison would have to be made between generation, IMO.
Old 10-22-2009, 02:53 PM   #9
Last I knew there was a casting defect in the SOHC heads that was never fixed. Then, just to add to the fun, in 2000 or 2001 the robots got drunk and put the intake manifold gaskets on folded over on themselves near the #1 cylinder.
Do SOHC Heads have the same problem with cracking as the 1994-1999 heads? BRIAN41920 S-Series Tech 2 10-22-2009 10:17 PM
Aftermarket SOHC heads???? NO_SPRK S-Series Tech 24 08-05-2009 07:06 AM
99 dohc heads on 96 sohc block youngrenton S-Series Tech 3 08-07-2007 08:10 PM
Need Advice.engine Exchange,1994 1.9 Sohc To A 1999 1.9 Sohc. Some Issues Include cakjoey S-Series Tech 5 10-08-2006 08:56 AM
Sources for new/rebuilt SOHC heads mdfrench S-Series Tech 1 12-06-2004 10:30 PM
