Old 07-11-2009, 02:27 PM   #1
07VUE
07VUE is on a distinguished road
07VUE's Avatar
Question Wiring diagram for mirror in 2007 Vue?
I have a 2007 front-wheel drive V6 Vue. It's equipped with a mirror that has OnStar buttons, a compass display, and shows the outside temperature. Does anyone know where I can find the wiring diagram?
I'm thinking about replacing the mirror with a Gentex model that has a similar compass display and shows the outside temperature but has Homelink buttons that I can program for our garage door(s).
Rather than having to run new wires, I'd prefer to "tap" the existing wire set coming from the outside temperature probe and providing power.
07VUE is offline   Reply With Quote
Old 07-11-2009, 03:32 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Wiring diagram for mirror in 2007 Vue?
My repair manual covers through 2005 so I really don't know if the 2007 is significantly different.
You can compare wire colors or hold off until something better comes along.
Good luck.
Old 07-11-2009, 03:58 PM   #3
07VUE
07VUE's Avatar
Thanks! That could very well be it. I'll have to compare it my Vue's harness, but it looks promising.
Taking OnStar out of the picture, I think the pin-out is as follows:
Yellow = 12 V
Black = Ground
Light Green = Backup Lamps (when "hot", mirror doesn't dim)
Light Green / Black = Temperature Probe
Gray = Temperature Probe
Old 07-11-2009, 04:51 PM   #4
emsvitil
emsvitil has a spectacular aura aboutemsvitil has a spectacular aura aboutemsvitil has a spectacular aura about
emsvitil's Avatar
I found some online wiring diagrams at www.autozone.com........
Ed
emsvitil is offline   Reply With Quote
Old 07-12-2009, 01:47 PM   #5
07VUE
07VUE's Avatar
I took a close look at my Vue's RV mirror wire harness and have confirmed it to be a match with the diagram far2grumpy posted. Thanks far2grumpy!!!
Now I just have to decide whether or not I want to spend what will likely be $225 or more when all I'm doing is eliminating the OnStar controls I have no use for and replacing them with what might just be a very expensive garage door opener.
2002 Saturn Vue Wiring Diagram / License Plate Light Trouble nickwisdom Vue General 1 10-31-2008 02:07 PM
Need wiring harness diagram for 2004 2.2L VUE kim_lombard Vue General 1 04-22-2008 08:29 AM
2007 Vue Passenger Mirror rshorty Vue Tech 2 02-19-2008 07:45 AM
2006 Vue Wiring Diagram Tek Vue Tech 0 04-08-2006 03:35 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 05-01-2005 12:45 AM
