Old 07-18-2016, 09:49 PM   #1
keith23464
keith23464 is on a distinguished road
Default 2007 Saturn Ion, gas issue after oil change
I have a 2007 Saturn Ion 4 door sedan. We took it in for an oil change. After they pulled the car out, when we started it, the car has a throttle issue. It starts but if you press the gas it just chokes up. It doesn't rev. It is not throwing off a check engine light. The company that changed the oil wants to change the coils, spark plugs, and spark plug cables and do a fuel system cleaning for $900.00. Any ideas what caused this issue? The car was fairly low in gas. Could it be the fuel filter?
It starts up, but pressing the gas peddle doesn't rev it. Help! I feel like I am getting screwed!
keith23464 is offline   Reply With Quote
Old 07-18-2016, 10:31 PM   #2
Lion IX
Lion IX is on a distinguished road
Default Re: 2007 Saturn Ion, gas issue after oil change
When my 2007 Saturn got to a little under 1/4 gas on the gauge, it started having trouble reaching high enough rpms. It would shift a lot on the interstate and have trouble keeping it at 60. It was also having this issue at lower speeds when I was exiting the highway. When I filled the tank, the problem went away completely. (I still want to change the fuel filter soon since I recently bought it and doubt it has ever been changed). I also plan on never letting the level get below 1/4 again (unless I feel like checking to see if the filter helped with that symptom).
As far as the oil change, I'd recommend checking their work if you're mechanically inclined at all. (check the level and color/condition of the oil on the dipstick). The symptom you're describing seems like nothing oil would do (unless something severely went wrong like having no oil/severely low).
The spark plugs, fuel cleaning, etc. was probably an upsell, but you definitely do want to keep on top of your maintenance items. Check the stickied thread in the Tech subforum for some common maintenance items (and refer to your owner's manual maintenance schedule).
Lion IX is offline   Reply With Quote
Old 07-19-2016, 01:34 PM   #3
keith23464
I thought I'd follow up with what transpired. I made a lot of calls today because I was certain that the oil change had to be the cause of the issue. Everyone that I called said the only way it could have happened perhaps is if they checked the air filter when the car was running during the oil change and maybe gunked up the mass air flow sensor. I pressed them to check it and finally they did and sure enough it was covered in crap and they cleaned it off and the car is fine now.
Old 07-19-2016, 01:37 PM   #4
keith23464
But that brings up a new question. They were telling me that the car was throwing off a code when they checked it but the check engine light never came on and they were thinking that someone might have disabled it or it was defective. Does anyone know how to test the check engine light to see if it is disabled or the bulb is out? Is there a way to force the check engine light to come on?
Old 07-19-2016, 01:40 PM   #5
billysvue
Of course they do... Give the a YELP or other review, then NEVER GO THERE again!
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 07-19-2016, 02:21 PM   #6
2006 ion2
2007 ION-2 Sedan
The bulb check is performed every time the key is turned to run.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 07-19-2016, 04:08 PM   #7
billysvue
I have a 2007 Saturn Ion 4 door sedan... change the coils, spark plugs, and spark plug cables and do a fuel system cleaning for $900.00. Any ideas? !
plugs, etc.( minus "fuel system cleaning"-> you can buy a bottle of Techron and a rattlecan of throttle body cleaner), costs for parts isn't much over $100 retail, if buying high end OEM and considerably lower if buying the cheapest ( the shop).
Easy peasy, driveway job for the 4banger Ecotec
http://www.rockauto.com/en/catalog/s...tion+coil,7060
http://www.rockauto.com/en/catalog/s...ug)+boot,10150
http://www.rockauto.com/en/catalog/s...park+plug,7212
'17 Suby Forester
Old 07-19-2016, 04:11 PM   #8
billysvue
THere a a few variations in engine size and transmission. What are your particulars
'17 Suby Forester
Old 07-19-2016, 11:48 PM   #9
ruley73
ruley73's Avatar
Short Answer: No.
Like 2006_ion2 said, The bulb check is performed every time the key is turned to the RUN position. All applicable warning lights are illuminated during the self-test.
The CEL is an LED (along with all the other warning lights) so it is impossible to disable unless said LED is removed from the PCB. The code they were seeing was probably a pending code. Only confirmed codes trigger a light. Pending codes are the ECM's way of saying "something's fishy here, but I need to run some more tests to confirm/negate this issue". Pending codes are can be retrieved by a scan tool and will be marked as "Pending", but don't trigger a light. When the ECM determines no issue exists, the pending code is deleted.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 201K miles
2018 Chrysler Pacifica Touring L 63K miles
Old 07-20-2016, 02:48 PM   #10
keith23464
Ruley,
Thanks for your explanation. That must have been it because I turned the car to the run position and the light came on just fine. They just obviously had no clue what they were doing. I will not be taking my car there anymore!
2007 Saturn Vue Automatic Transmission Fluid Change greensaturn How-To Library 13 11-04-2018 09:31 PM
2007 Saturn VUE A/C Issue aerial_22 Vue Tech 15 08-06-2014 11:33 PM
2007 Saturn Vue Stalls/Trans issue, etc melly1234 Vue Tech 4 05-15-2014 03:14 PM
2007 Ion oil change....help Frez Ion Tech 40 09-09-2007 09:37 PM
2007 Vue first oil change greensaturn Vue Tech 5 12-03-2006 03:44 PM
