Old 06-09-2016, 05:06 PM   #1
boat-tech25
boat-tech25 is on a distinguished road
Default Stalling issue
Can anyone help,
2004 Vue 2.2 lt. occasional rough idle, stalling when coasting to a stop.
Have replaced crank position sensor, cleaned air temp sensor, fuel psi remained above 50 psi when it stalled. Someone told me air temp sensor is being used as a mass air flow sensor. Has left my wife stranded and i only could get it to stall for me one time. It started back up ran rough for a second then fine after that. No codes logged in computer. Any help would be greatly appreciated.
boat-tech25 is offline   Reply With Quote
Old 06-09-2016, 11:12 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Stalling issue
Originally Posted by boat-tech25 View Post
Can anyone help,
There are some really smart 2.2 owners who will probably offer quality advice ... looks like you're stuck with me until they weigh-in.
I've attached three FSM extracts pertaining to problems similar to yours. There's a whole shopping list of possibilities and you've probably completed some of them. Send a PM with email address if you'd like any of the referenced files.
From my own experiences and reading many 2.2 threads I could suggest a few off-the-wall possibilities:
Could be a bad pre-cat O2 sensor - they've been known to provide really bad fuel advice to ECM - especially after engine reaches normal operating temperatures. One clue is if engine starts and operates normally for a short period and then starts to misfire. The preferred method to eliminate sensor is to locate the wiring harness connection and unplugging sensor. You can operate engine as much as you like - however, it will be running in OPEN loop which means you'll be able to smell a rich mixture in exhaust, mileage will be poor and you'll never pass emission testing.
Is there any correlation with misfiring and filling gas tank? There's an EVAP purge valve on engine - commanded by ECM - that selectively draws fuel fumes from gas tank through a carbon canister on as required basis. If this valve sticks open the engine vacuum system is compromised and engine will not run smoothly - if at all.
Another possibility is a clogged exhaust system. I've had this problem in past where a piece of debris in muffler would intermittently block the exhaust and engine will cough, spit and refuse to operate normally until the blockage is removed. You can isolate this problem in minutes if you have access to a simple vacuum gauge.
Old 06-10-2016, 12:23 AM   #3
While waiting for smart 2.2L owners to chime in, there may be some other easy things to check. What's mileage? Spark plugs replaced at 100k miles? Air filter? Throttle ever cleaned?
Old 06-10-2016, 06:11 AM   #4
waiter21
2003 VUE 2.2L
Is the Service Engine soon light on? Are there any codes set?
Old 06-13-2016, 07:14 PM   #5
boat-tech25
Thanks to all, have finally resolved issue, Replaced what saturn called the air temp. sensor or air charge sensor. Now runs smooth as silk and no more stalling. To answer your questions for help with future similar inquiry's, mileage 128,000. spark plugs changed on schedule, no misfires ( have scanner to confirm ) pre O2 thru a code recently and was replaced. I'm back in good graces with my wife.
Thanks again.....
Not starting issue became a stalling issue l3uster L-Series Tech 19 05-12-2014 02:05 PM
its been a bad day.....stalling issue. please help solarcar_sc1 S-Series Tech 5 04-27-2014 02:35 AM
99 sl2 stalling issue sccaligirl S-Series General 13 01-15-2014 02:30 PM
Please Help! 03 Vue Stalling Issue Cindy17932 Vue Tech 2 02-26-2013 07:26 PM
97 SC2 Stalling Issue dsorenson28 S-Series Tech 4 01-14-2007 01:27 PM
