Old 11-19-2008, 02:13 PM   #1
savage21
savage21 is on a distinguished road
Default Rough IDLE/Low IDLE no check engine light
Notice the rough idle about a month ago and figured its was plugs so I changed them and the air filter and still idles rough and maybe low as well any ideas on what to check for next??
Thanks
savage21 is offline   Reply With Quote
Old 11-19-2008, 02:23 PM   #2
Growser
Growser is on a distinguished road
Growser's Avatar
Default Re: Rough IDLE/Low IDLE no check engine light
Having a year, model of the car helps with replies. Have you replaced the temperature sensor for the coolent? Lots of running problems if it's not working. It's a cheap fix, and a common problem. The factory one is plastic and is known to crack. You should replace it with the new brass one. Go to the How To Library search for more information on the repair. It is also abreviated as ECTS. Check here for the video http://www.saturnfans.com/forums/sho...d.php?t=124184
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Growser is offline   Reply With Quote
Old 11-19-2008, 02:47 PM   #3
savage21
sORRY ITS A 2002 VUE 2.2L i WILL CHECK THE COOLANT SENSOR ANYTHING ELSE TO CHECK FOR
tHANKS
Old 11-19-2008, 03:06 PM   #4
Don't bother about the coolant sensor as it affected only the S-series cars until '01. Everyone else has the brass sensors already as GM/Saturn quietly figured this out before infecting the rest of the Saturn line.
You might have to consider a dirty throttle body needing some cleaning. Its always helpful to post all information at the beginning including mileage so 'twenty questions' are avoided.
Old 11-19-2008, 03:20 PM   #5
savage21
Something else I just remembered! It Idles rough except when cold and when its warmed up the rough idle can fluctuate sometimes and you actually see a drop in RPM then it recovers again but still idling rough
Its has around 96,000 miles
Old 11-19-2008, 08:44 PM   #6
savage21
Im really stuck on this one anyone else have any ideas
Old 11-07-2010, 05:57 PM   #7
Joshtheclockman
Joshtheclockman has a spectacular aura aboutJoshtheclockman has a spectacular aura aboutJoshtheclockman has a spectacular aura about
1994 SL
2002 SL
Does the rpm drop and recover repeatedly? if it does its possible you may have a vaccume leak...
Joshtheclockman is offline   Reply With Quote
Old 12-03-2010, 10:57 PM   #8
jhonky
jhonky is on a distinguished road
might need a new thermostat
jhonky is offline   Reply With Quote
Old 12-07-2010, 07:28 PM   #9
MerrittK54
MerrittK54 will become famous soon enough
MerrittK54's Avatar
2009 VUE 2.4L
2009 AURA XR
Savage21, you and I have the exact same problem. See my thread I started entitled "Throttle Valve Flutter". Except for Mr. Far2Grumpy, I can't get any feedback. The vaccum leak possibility that was suggested to you may be a good lead. Have you tried to diagnose your problem by checking for vacuum leaks?
2009 Aura XR 2.4L (Wife's)
2009 Vue XE 2.4L(Mine)
2002 L200 (Daughter's)
MerrittK54 is offline   Reply With Quote
Old 12-08-2010, 01:27 AM   #10
bluesl2
bluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of light
bluesl2's Avatar
Do a compression test, or maybe partially plugged injector. What would be beneficial is to actually see the live data from the ecm for misfires if there are any.
Rough Idle, Blinking Engine Light RySci Ion Tech 15 01-13-2009 12:17 AM
2002 L 100 service engine light and rough idle oscar5150 L-Series Tech 5 10-24-2006 10:57 PM
service engine soon light, idle a bit rough tdm850rider S-Series General 24 01-26-2006 05:14 PM
rough idle and check engine light t0pk0w S-Series Tech 3 01-03-2004 11:28 AM
SES light rough idle after engine cleaning debaser S-Series Tech 4 07-31-2002 10:19 PM
