Old 03-03-2007, 09:07 PM   #1
NVMY03GT
NVMY03GT is on a distinguished road
Default Next Steps?
Alright so now I am just well beyond pissed. This weekend I took off my tensioner and replaced it. About 3 hours worth of work right? Well not the problem. I got it all back together - fire'd it up. The noise just reappeared. Someone had mentioned a mount below the tranmission is rattling against something? I don't know I don't know where to go from here. When the belt is OFF the car the noise isn't there. When the car is in gear (Reverse or Drive) it's like Metal against metal.
Ideas?
Please help Im literally going to kick a hole in this car
Be nice to me - Im still Learning
2003 Saturn Ion 3
NVMY03GT is offline   Reply With Quote
Old 03-03-2007, 09:47 PM   #2
Phredawgy
Phredawgy's Avatar
Default Re: Next Steps?
have you changed the idler pulley itself?
Old 03-03-2007, 10:11 PM   #3
mkuz13
mkuz13 is on a distinguished road
2009 AURA XE
Does your a/c work?
If it does,turn it on and see if the noise changes.
Want more gun control? Then use both hands.
mkuz13 is offline   Reply With Quote
Old 03-03-2007, 10:22 PM   #4
When you had the belt off, did you take the time to spin all the other pulleys (A/C, water pump, idler, P/S, alternator), and listen/feel/look for noise, roughness, looseness, etc?
Old 03-03-2007, 11:16 PM   #5
NVMY03GT
Idler Pulley - tested - no noise. Didn't spin the other ones because they aren't as easy to spin free based I moved the power steering and again no noise.
Idler pulley was free spinning no issues.
A/C Doesn't work right now.
2003 Saturn Ion 3
Old 03-03-2007, 11:39 PM   #6
mkuz13
2009 AURA XE
Best investment is go to the auto parts store and purchase a automotive stethoscope.Then you can pin-point where the sound is comming from.
Note-if you do buy a automotive stethoscope,make sure you dont put the tip on any moving parts.
Old 03-04-2007, 12:01 AM   #7
NVMY03GT
Well riddle me this for a minute.
Timing Chains. Persay If it WAS a chain would it rattle with or without the belt?
Someone else suggested a heat shield possible?
Also the noise disappears at higher rpms.
How much is a NEW engine again?
2003 Saturn Ion 3
Old 03-04-2007, 12:44 AM   #8
Tiger
Tiger's Avatar
Congratulations on getting the tensioner replaced!
As far as new engine, on an older car, it would be cheaper to buy a used engine from a junk yard. But, my question is, if you do need an engine, do you want to replace it? Your A/C is not working. My (bad) experience was A/C repairs can be very costly. Add up all that needs to be done, factor in own ability to do repairs, or pay someone to do them it might = a different car. I am not very good at diagnostic. I tended to take it to someone else for that. You are also getting a flavor how difficult diagnostics and repairs can be. I have found it not so easy. I hope things work for you. I have been there, and it is not fun!
Old 03-04-2007, 01:38 AM   #9
Phredawgy
Phredawgy's Avatar
could be the AC pulley......or the alternator....or it could be like mine...an idler pulley that was going bad but at first spin....(without the belt) made no noise....just felt funny......I think you can get a serpentine belt to bypass the ac pulley.....I wonder if that wouldn't get it.....
Old 03-04-2007, 08:44 AM   #10
NVMY03GT
Well and thats my fear. I took on this tensioner job not know what I was getting into. Im guessing the next thing that it could be is Timing chain. The car has been ran low on oil MULTIPLE times and from what Ive read on here when running the engine low on oil the timining chain begins to go. The part I don't understand is If it WAS the itming chaing shouldn't it so it with the Belot off also? That confuses the hell out of me
The only reason I suggested another enigne is because it is a timing belt you could probably get an engine from a junk yard for a couple hundred WITH the timing chain already assembled. The bad part is I have no cliue how to put an engine in nor would I try to do it myself. Too much ****t o hook up on that stuff.
Timing Chanin is what 700 to 800 to fix? Roughly? thats on the low side Im sure. I just wish I could confirm if it was a timing chain or not that would put my mind down a little bit. Im affraid to toss in the towel too early.
2003 Saturn Ion 3
2.2 Ecotec Power steps philip1 L-Series General 71 02-08-2017 02:59 PM
Anyone know the steps for replacing the BCM? bradnelson Vue Tech 1 07-01-2008 10:26 PM
Tubular assist steps detector19 2008 Vue 0 06-14-2008 04:25 PM
Side Steps! DJPSC Vue General 11 12-17-2004 12:35 AM
