Old 01-09-2005, 12:22 PM   #1
SweetSL2
SweetSL2 is on a distinguished road
2003 ION-2 Sedan
Dazed Motor Mount Question
Hey Everybody,
Got a 96 SL2 and it has a bad motor mount. I have checked the Torque Axis Mount and it looks good. No cracks or signs of it being worn down. My question is how do I know whether it is the tranny mount or the dogbones? I have looked at my engine and when I shift from Park to Drive, the engine moves a lot on the right side(side where the battery is on). This is also causing my flexpipe to shake during acceleration(sounds like a angry slinky). And also, I've been looking at the dogbones from SMS, any one have any feed back on them
Thanx
LP
SweetSL2 is offline
Old 01-09-2005, 01:28 PM   #2
Razorbak
Razorbak's Avatar
Default Re: Motor Mount Question
Originally Posted by SweetSL2
Hey Everybody,
Examine them visually for cracks, missing pieces, or collapsing of the rubber or steel components.
The trans pad mount underneath the transaxle can be viewed easily by removing the splash shields in the left front fender well. Don't remove the wheel; just turn it to one side using the steering wheel to provide better access.
The trans strut (dogbone) can be viewed on top of the transaxle by removing some stuff from the front driver's side of the engine (e.g., airbox, battery, and/or battery tray... can't remember the specifics offhand, because it's been a few weeks since I did this myself).
The engine strut (dogbone) can be viewed underneath the crank pulley/harmonic balancer by removing the splash shield(s) in the front passenger footwell. Again, don't remove the wheel; just turn it using the steering wheel to provide better access.
Razorbak is offline
Old 01-09-2005, 08:26 PM   #3
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
That lower trans mount is just a pad the tranny sits on. It doesn't fail NEARLY as often as dogbone mounts, that take a huge beating. Replace those, your tranny mount is fine.
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
bennett9000 is offline
Old 01-10-2005, 11:09 AM   #4
Luke
Luke's Avatar
Regards ^^^^^, and in my case, it was the reverse ; the transmission mount had shrunk, while the dogbone was fine (changed it anyway, though).
Luke is offline
Old 01-10-2005, 10:08 PM   #5
SweetSL2
2003 ION-2 Sedan
Well, thecar has 120,000 miles on it, so it might be time to change them all out anyway.
SweetSL2 is offline
Motor mount question reelon S-Series Tech 13 12-10-2006 01:42 PM
Motor mount question rreuben S-Series Tech 5 11-19-2006 04:16 PM
Upper Motor mount question OU812 S-Series General 5 04-07-2006 09:44 AM
yes a motor mount question 71_307 S-Series General 4 07-07-2005 07:44 PM
Motor Mount Question Aldiaz2331 S-Series Tech 2 12-13-2003 12:36 PM
