Old 05-12-2021, 09:51 PM   #1
DevinPotter
DevinPotter is on a distinguished road
1998 SL1
Default Fuel Injector Tester cleaner kit EM276 whats your thoughts
Has anyone used a Fuel Injector Tester cleaner EM276 tool ?
Part link :
https://www.amazon.com/dp/B07VC37VRB...HP5XNHK4GEWN5J
Reason :
Im doing is this to just keep my car on the road more figure why not spare time proactive 280k+ maybe see some gains Who Knows
If anyone can share what resistance/Ohms should be or any normal test results be please share
1998 Saturn SL1 SOHC
Whats everyone's Thoughts
DevinPotter is offline   Reply With Quote
Old 05-12-2021, 11:46 PM   #2
billr
Default Re: Fuel Injector Tester cleaner kit EM276 whats your thoughts
It looks like that doesn't do anything but power the injector. That can be done for $0-5, depending on the injector type and your cleverness.
Old 05-13-2021, 12:03 AM   #3
Looks expensive when all you need is a 12vdc source, a pigtail from the factory wiper fluid pump* and a can of carb clean.
*unless you have a '02 or late '02 with the funky injectors.
Old 05-13-2021, 12:23 AM   #4
Waiex191
Waiex191's Avatar
That works the best if used in conjunction with the EFFuel fuel economy chip.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-13-2021, 01:03 AM   #5
Cheyne
Cheyne has a spectacular aura aboutCheyne has a spectacular aura about
2000 SL2
It will help to clean injectors, but this is not the tool's primary purpose. It is used to test injectors and balance test them when used in conjunction with a fuel pressure gauge.
Old 05-13-2021, 01:46 AM   #6
A few members here created their own home made injector tester using a door bell transformer (120vac input, 16 vac output). Some skills needed to supply solvent under pressure. The ac voltage output lets the injector cycle (crudely) enough to allow solvent to spray out to display a pattern for comparison to other injectors. Search past threads of these diy injector tests/cleaner. The spray is a great visual to compare with the others while letting solvent clean up any buildup. Gasoline is already a solvent but not recommended for this otherwise the injector becomes a flame thrower if inadvertently ignited.
The specs of the ALLOSUN injector tester has adjustable pulse settings. This may be the latest inexpensive way to have near professional injector cleaning services at diy prices. And with amazon, a money back guarantee if the product doesn't perform as advertised. Check before ordering if the product is returnable if not satisfied.
I ordered a product from amazon and was disappointed with it after exhausting every effort to have it work. Disappointed, I emailed amazon with my concerns and was promptly asked if I wanted to return it for refund. I opted to try a replacement instead. The replacement worked as advertised, a return shipping label was included to send the faulty one back. Overall, I received a good product the second time around without problems.
Old 05-13-2021, 05:50 AM   #7
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Cheapo DIY kit...
https://www.aliexpress.com/item/1005...archweb201603_
SMB Fuel Injector Cleaner For a $1.00 brags S-Series General 4 02-20-2013 10:38 AM
best fuel injector cleaner ? 97sl2DOHCaut1.9 S-Series Tech 11 07-09-2010 12:44 AM
best fuel injector cleaner? xupthree60 S-Series Tech 10 11-28-2006 03:56 AM
fuel injector cleaner PaulN64 Mods and Performance 8 09-22-2005 12:21 PM
Fuel Injector cleaner's are for real? SpencerportNY S-Series General 7 07-14-2005 06:37 AM
