Old 08-11-2017, 04:15 PM   #1
Red5
Red5 is on a distinguished road
Red5's Avatar
2008 Astra XR
Default K&N 57S-4900 Performance Intake Kit
Has anyone tried this?
K&N performance air boxes are designed to dramatically reduce air flow restriction as well as smooth and straighten air flow. This allows your engine to inhale a larger amount of air than the factory air filter assembly. More air means more usable power and acceleration throughout the engine’s RPM range. The 57S-4900 Performance Airbox comes with a custom shaped K&N high-flow air filter and a fully enclosed injection molded air box that connects up to the factory air intake hose. The air box has a removable lid for easy access to the filter when cleaning is required.
Red5 is offline   Reply With Quote
Old 08-11-2017, 05:54 PM   #2
AstraFasta
Default Re: K&N 57S-4900 Performance Intake Kit
Several people have tried these intakes with mixed results.
The Astra seems to be hypersenstitive to oil & dirt on the MAF and throttlebody. Runs terribly when these get a bit dirty. I run a good paper airfilter in the stock box but need to clean the MAF and throttlebody annually. With a K&N you may need to clean more often.
I seem to recall some other drivability or code issues but just do a search.
These engines are not high performance. Best performance upgrade for the price is to run premium fuel (and keep the air filter-MAF-throttlebody clean).
Old 08-13-2017, 08:05 AM   #3
DJWFire2
DJWFire2 is on a distinguished road
Would you happen to know the price and if it would work for a 5 speed manual '02 L200 2.2?
DJWFire2 is offline   Reply With Quote
Old 08-13-2017, 09:13 PM   #4
Red5
Red5's Avatar
2008 Astra XR
I must not search very well as I found nothing on this intake. I like that it has a box to muffle the intake noise (would not consider an open CAI). I run a K&N drop in filter and think in the humid southeast they help, but not much.
It's $159.00 with free delivery from K&N (800)-858-3333 but this one is specific to the:
The K&N 57S-4900 Performance Air Intake System fits some Holden Astra, London Taxi TX4, Opel Astra G, Opel Astra H, Opel Zafira, Opel Zafira II, Saturn Astra, Vauxhall Astra Mk4, Vauxhall Astra MK5, Vauxhall Zafira, and Vauxhall Zafira MK2 models.
The K&N website has a search function by make but I can't post the URL until after the 15th post. Sorry man.
Old 08-13-2017, 11:24 PM   #5
Red5
Red5's Avatar
2008 Astra XR
This is the other option but it costs nearly twice as much and comes from across the pond. Also, There was no exact match but this one came closest.
CDA - CARBON DYNAMIC AIRBOX - ACCDASP-08
Code: ACCDASP-08
D1 (mm): 70
D2 (mm): 150
L1 (mm): 160
For:
Alfa Romeo GTV 2.0 TS 16V
Alfa Romeo GT 2.0 JTS
Honda Civic 1.7 CDTI
Opel Astra H 1.9 16V CDTI
Renault Clio II Series RS 2000 172HP ('01>'03)
Seat Altea 1.9 TDI
The Holden version of the Astra had an optional 2.2 L engine or a 2.0 L turbo, which must have been nice. Any tweak we can make to bump power up a bit (hoping for 5 bhp) can be absorbed without needing to upgrade drivetrain or brakes.
Old 08-16-2017, 05:34 PM   #6
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
I have that K&N filter installed in my car for almost 6 years now with no major issues. Like most have said you just need to keep on top of cleaning the filter, MAF sensor and throttle body. You will still get a lot of intake noise because there is quite a bit more air coming. I have the intake installed with the vxr intake snorkel and a derestricted airbox.
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Old 08-16-2017, 09:51 PM   #7
Red5
Red5's Avatar
2008 Astra XR
Many thanks; I've ordered the snorkel and am looking forward to seeing how it changes things. I mentioned this in another thread but there's a small restriction on the top side of the air box as well; it's easy to remove with small flat head and pliers (then sand the plastic lip it sat against flush)
Performance Air Intake heresy_fnord Sky Red Line 19 09-26-2012 07:24 AM
DIY Performance Intake diplo Astra General 7 03-27-2009 04:14 PM
any performance from an intake? crazynate S-Series Tech 26 09-15-2005 10:43 AM
will buy a performance intake nkyleft Classifieds 9 07-24-2003 04:04 PM
Performance intake for the ION!!!! StreetDesign Ion General 20 03-23-2003 08:50 PM
