Old 08-23-2014, 01:54 PM   #1
ionplus
ionplus is on a distinguished road
Default aftermarket stereo install question
I am about to install an aftermarket stereo in my '03 ion, which still has the original antitheft unit. Is it necessary to use the gm2000 adapter? All the info I have found seems that it just affects the door chimes, but have seen first hand what an improper install can do. any good thoughts or experiences in this regard?
ionplus is offline   Reply With Quote
Old 08-23-2014, 02:01 PM   #2
Belac360
Belac360 is on a distinguished road
2003
Default Re: aftermarket stereo install question
I just ordered my unit from crutch field and nothing was mentioned about that so I'm assuming if you get the right wire harness everything will work as it should.
Removing the stock unit is super easy. pop the cover off with a screwdriver or just give it a little tug and it comes off then the unit is held in by two screws. Takes 2 minutes to remove it from the car.
I will be able to update more when I actually do the install if everything works as it should but I don't think that anything will not work.
Belac360 is offline   Reply With Quote
Old 08-24-2014, 05:05 PM   #3
ruley73
ruley73's Avatar
As long as you don't have OnStar, all you need is a wiring adapter and mounting kit. The Ion still has a separate chime speaker that is integrated into the gauge cluster. The chime is not integrated into the radio unlike most other newer GM vehicles.
2007 Chevy Equinox LT 201K miles
2018 Chrysler Pacifica Touring L 63K miles
Old 08-25-2014, 01:15 PM   #4
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
like balec said, make sure you have the correct harness. there are several out there for GM vihicles that are the same plug, but different wiring. you will also need a mounting kit if its a single dinn stereo. double dinn stereos should be able to use the side brakets that are on the side of the factory radio.
03 ion-2 Sedan 5sp
94 Honda civic automatic "VTEC yo"
05 Santa Fe 2.7L (Fefe) {Wrecked}
"A problem clearly stated, is a problem half solved."
♕KCCO
kevin.st56 is offline   Reply With Quote
2006 Ion 2 Aftermarket Stereo Install ??? 06atomicion Ion General 6 11-24-2016 04:35 PM
Need help with Aftermarket Stereo Install mtu_astra Astra General 5 02-09-2010 12:36 PM
aftermarket stereo install ? blockrockin 2008 Vue 11 12-31-2007 04:59 PM
VUE Aftermarket Stereo Install kolonay Vue General 17 10-30-2005 05:00 PM
2004 Ion Aftermarket Stereo Install freyguy8 Ion General 27 09-17-2005 11:31 AM
