Old 03-12-2013, 08:25 PM   #1
kknobl
kknobl will become famous soon enough
kknobl's Avatar
2009 AURA XE
2008 Outlook XE
Default Door latch
All,
Recently, the driver's door in my Aura will, on occasion, not shut properly. I close the door and it sometimes will bounce back open, almost as if the latch was not properly "resetting." I locked\unlocked a few times (to test the actuator) but that didn't cure it, so I pulled the outside handle again, and the door closed fine.
All other doors shut properly, so I looked at each latch to try and figure out what was different among the three operating properly. I noticed a gray lubricating gel noticeably present on all three of the four doors. The driver door, however, seemed to have non-existant lubricant. Pics attached:
Driver Side:
Left rear:
Right Rear:
Passenger front:
Any ideas as to what type of lubricant this may be, before I attempt changing the latch entirely?
kknobl is offline   Reply With Quote
Old 03-12-2013, 08:35 PM   #2
golftango
golftango will become famous soon enough
golftango's Avatar
Default Re: Door latch
Multi-Purpose Lubricant, Superlube (GM Part No. U.S. 12346241, in Canada 10953474).
2017 Sport SE 6MT in San Marino Red
2012 Pilot EX-L w/ NAV (family truckster)
http://www.flickr.com/photos/golftango
https://500px.com/golftango
https://www.instagram.com/golftango
golftango is offline   Reply With Quote
Old 03-12-2013, 08:43 PM   #3
kknobl
kknobl's Avatar
2009 AURA XE
2008 Outlook XE
Awesome! Thanks for the quick help. Hopefully it kicks the problem.
Old 03-12-2013, 11:43 PM   #4
greenman
2009 AURA XE
I use white grease spray, available anywhere.
Old 03-14-2013, 07:23 PM   #5
lugnuts
lugnuts is on a distinguished road
lugnuts's Avatar
2009 AURA XR
I got in a pinch in NJ where my door wouldn't open. My key fob essentially had cold joints so I can't cycle the locks. I was locked in! In a pinch I removed the inner door panel, reached my hand inside where the door lock cable was and pulled. Once free the only thin I had handy was 5w-30 and shop towels. I cleaned the mechanism and put a light coat of oil on the lock. Viola problem solved.
lugnuts is offline   Reply With Quote
2007 Door Latch Broken (door closed) dixonba Ion Tech 0 06-20-2012 11:50 PM
where to get door latch cstiles S-Series Tech 3 01-01-2011 01:47 PM
Door Latch mike634 S-Series General 2 07-26-2010 06:22 PM
ADVICE? - Screwed up door latch installing door speaker greasemonkey26 S-Series Tech 4 01-07-2008 03:26 PM
door latch dignusone S-Series Tech 0 06-09-2006 05:41 PM
