Old 03-14-2010, 11:48 PM   #1
motoboymatt
motoboymatt is on a distinguished road
Default P0304 and P0507 Codes On 2002 SL1 = Leaking Intake Manifold Gasket at #1 Cylinder
Have P0304 and P0507 codes, compression checked out at 150 psi on #4, while looking online for confirmation of cylinder numbering found out that P0301 and P0507 codes point towards intake manifold gasket. Checked the ITM with carb cleaner at #4 with no change in idle. Moved to #1 and found definate vacuum leak. This confirms my previous experience that misfire monitor is not 100% accurate at determining which cylinder is misfiring.
motoboymatt is offline   Reply With Quote
Old 03-15-2010, 12:10 AM   #2
Default Re: P0304 and P0507 Codes On 2002 SL1 = Leaking Intake Manifold Gasket at #1 Cylinder
Verify that your firing order is correct also. You can switch #1 and #4 at the coil and the car will run. With 150 psi in #4 it may not fire and #1 may well be firing even with an intake leak. 150 psi is 30psi below the service limit and you can expect misfiring at idle with that low compression.
Old 03-15-2010, 01:09 AM   #3
motoboymatt
Now that you mentioned it, I've had a P0341 code since I've had the car so that could be why it's confusing #1 and #4, considering it doesn't have a cam position sensor. Can you provide a reference for 180 psi being the lower limit on compression? That seems a bit high.
Old 03-15-2010, 09:21 AM   #4
FSM 190 minimum, 180 service limit. You have a burnt valve in #4 most likely and an intake leak. Coil firing order left to right as looking down on it 4-1-2-3.
Clean tight engine is 230 psi or so.
Old 04-24-2010, 06:28 PM   #5
motoboymatt
It's been a month since I did the intake gasket and the car is running great. Codes P0304 and P0507 are gone.
Intake Manifold Gasket/2002 SL1 Jhawk S-Series General 8 12-14-2011 04:59 PM
Leaking intake manifold? dj1111 S-Series Tech 1 11-25-2008 02:27 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 03:42 AM
2001 intake manifold leaking coolant? MiNiMaTiC S-Series Tech 2 01-10-2008 02:08 PM
2002 SC1... Need new Intake Manifold Gasket?? WrathX S-Series General 4 12-11-2005 01:34 AM
