Old 04-15-2021, 12:39 PM   #1
cltrailer43
cltrailer43 is on a distinguished road
Default 07 Ion 2 - engine compatibility 2.2 California / Federal
I have a 2007 Ion 2, 2.2 engine, California NU6 with hole in exhaust manifold, Air valve etc. Looking to get replacement engine. Found one, but it is NOT California. Can I use that other engine, just use my ex manifold and intake manifold? Basically use it as a short block? or is the head and cam sensors, etc different with California vs Federal. I have read and read and read but cannot pinpoint for sure. I am pretty sure, just want to make sure before I buy the new engine. ANy input would be appreciated. Thanks!!
cltrailer43 is offline   Reply With Quote
Old 04-15-2021, 01:31 PM   #2
Default Re: 07 Ion 2 - engine compatibility 2.2 California / Federal
I'm inclined to believe all 2.2L ecotec engines are the same engine block internals with ancillary parts needed to separate federal from California engines. The ecm/pcm may have a different tune to accommodate air injection from non air injection. You might find others with more expertise in other Ion forums as well as other GM forums/models using the same ecotec engine with the same questions asked here.
If you cannot find an answer then perhaps calling/writing/emailing GM headquarters may result in someone knowledgeable enough to give you info. There's always local GM service centers to ask.
Is there a special California SL engine? coachlove S-Series General 2 05-06-2011 03:22 PM
94 california engine swap sl2 question freon480 S-Series Tech 3 04-29-2010 12:13 AM
1999 SL SOHC engine compatibility and PS compatibility rich_d S-Series Tech 6 01-10-2010 06:10 PM
Should I Install California or Federal Catalytic Converter? Zeroherokid S-Series Tech 2 10-06-2007 01:59 AM
California emmissions engine swap Zeroherokid S-Series Tech 5 05-31-2007 02:13 PM
