Old 01-23-2011, 08:06 PM   #1
casaturn
casaturn is on a distinguished road
Default L300 camshaft sprocket bolt
ok thanks
casaturn is offline   Reply With Quote
Old 01-23-2011, 08:17 PM   #2
Default Re: L300 camshaft sprocket bolt
Using '03 specs (presuming they're all the same) from the service manual;
Camshaft Sprocket Bolt
First Pass 50 Nm/37 lb ft
Second Pass 60 degrees
Final Pass 15 degrees
Reuse the same bolts.
Old 01-23-2011, 08:51 PM   #3
casaturn
Oh F-me!
I went back and reread the torque specs again in the manual (for about the 12th time), and _finallly_ noticed I was reading the crankshaft sprocket bolt torque, not the camshaft sprocket bolt torque.
THanks for the quick reply, and thanks for not pointing that I'm an idiot. I suspect you recognized my error, but were nice enough not to point it out.
Old 01-23-2011, 08:54 PM   #4
We all make mistakes. Welcome to Saturnfans!
Tags
bolt, camshaft, sprocket, torque
2002 Vue Camshaft bearing bolt torque specs Jason1979 Vue Tech 1 10-01-2010 07:04 PM
camshaft sprocket removal(sohc) suggestions? tgferg67global S-Series Tech 1 06-13-2010 11:38 AM
SOHC Camshaft Bolt Removal Clickety_Clack S-Series Tech 9 10-29-2008 10:47 AM
DOHC camshaft bolt sequence? davemac2 S-Series Tech 5 12-10-2005 01:36 PM
Camshaft sprocket removal '95 DOHC. Abe95SC2 Miscellaneous Tech 5 03-31-2002 09:04 PM
