Old 05-02-2022, 09:00 PM   #1
littlep2000
littlep2000 is on a distinguished road
Default Door Lock Failure
All door locks suddenly failed. Fob does nothing, nor does center console button. Unlike another issue here my hatch does not work either. I replaced the 25 amp door locks fuse in the luggage fuse box as it was blown but this did not fix the issue.
Has anyone had this before and managed to fix it? Thanks!
littlep2000 is offline   Reply With Quote
Old 05-02-2022, 10:45 PM   #2
littlep2000
Default Re: Door Lock Failure
Ended up finding elsewhere to disconnect the battery for a bit, probably over 5 minutes in my case.
The door locks work again except for the gas cap lock. I'm wondering if the solenoid went and tripped the fuse. I will dig into that a little more, but if all it means is leaving the fuel door unlocked of manually toggling it I am okay with that.
Old 05-03-2022, 02:46 PM   #3
Astra08
Astra08 is on a distinguished road
Astra08's Avatar
2008 Astra XR
If your airbag light was illuminated, I would suggest checking the connection back to the door release button back on the dash, but sounds like you addressed it.
My car does not have a fuel door lock, interesting.
Where to buy door lock housing, or door lock kit for 2002 Saturn SL? clinteastwood S-Series Tech 7 04-20-2018 02:27 PM
New Ignition Lock Cylinder Failure jeffsal87 S-Series Tech 6 02-15-2016 01:45 AM
Manual door lock will lock but when I close the door it will unlock. mmarquez S-Series Tech 4 04-08-2015 08:26 PM
03 L300 neither front door lock switches work. FOB & auto lock does. empireautomotiv L-Series Tech 3 08-22-2012 02:44 PM
Class Action Lawsuit for pass lock failure GM-Gov't Manage Ion Tech 3 03-31-2012 07:55 PM
