Old 01-04-2014, 06:18 PM   #1
Caniacfan17
Caniacfan17 is on a distinguished road
Dizzy 2001 SC2 p0301 code
Just bought this vehicle and it has 163,000 miles. When I got it, it had 5 codes stored, all leading to a tune up. I replaced both coil packs, all wires and plugs, and pvc valve. Reset the light and drove about 150 miles and the ses light came back. 19 DOHC, Now the only code it has thrown is the p0301. Any ideas on where to start next?
Caniacfan17 is offline   Reply With Quote
Old 01-04-2014, 06:21 PM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: 2001 SC2 p0301 code
I would suggest doing a Compression test on Cylinder 1 and report back your results, Being yours is a DOHC that rules out a possible intake gasket failure.
CHECK YOUR OIL!
Old 01-04-2014, 06:24 PM   #3
Caniacfan17
Thanks! What would be acceptable compression range?
Old 01-04-2014, 06:33 PM   #4
SL19302
SL19302's Avatar
2002 SL1
Anything below 180 PSI usually indicates a problem.
CHECK YOUR OIL!
Old 02-02-2014, 04:52 PM   #5
Caniacfan17
First issue was the wrong plugs were installed. Just replaced with NGK Platinum. Tested compression. Cylinder 1 was at 205 and all others were in the 190-195 range. Reset the light and will see what happens. If it pops again, where would you go next?
Old 02-02-2014, 07:52 PM   #6
billr
Swap the #1 fuel injector with another one, see if the misfire follows the injector or stays on #1.
Old 02-02-2014, 11:36 PM   #7
SL19302
SL19302's Avatar
2002 SL1
+1^^^ Swap the injector to another cylinder.
CHECK YOUR OIL!
Old 02-03-2014, 07:05 PM   #8
Caniacfan17
Dizzy Re: 2001 SC2 p0301 code
Well of course I have the old P0301 again and this time we have a P0410 to go with it. Haven't had time to try swapping the injector yet but will do. Any idea on the P0410? Is Iit EGR?
Old 02-03-2014, 07:09 PM   #9
SL19302
SL19302's Avatar
2002 SL1
Originally Posted by Caniacfan17 View Post
we have a P0410 to go with it. Any idea on the P0410? Is Iit EGR?
No its the air pump system, More then likely the exhaust manifold or air tube going to the exhaust manifold is clogged up with carbon and needs to be cleaned out. Heres a video on troubleshooting the air pump system.
http://www.youtube.com/watch?v=dIrmkxj6wJE
CHECK YOUR OIL!
Old 02-10-2014, 10:55 AM   #10
Caniacfan17
So far so good. Airpump checked out fine as well as the diverter valve. Found the thin rigid tube running across the valve cover to be disconnected on the back side so no vacuum was present at the switch. Connected it up and reset the codes. It's been 150 miles and 8 full hot/ cold cycles without a hitch
Appears as of now like it's fixed! Thanks for all the help!
Tags
2001 sc2, dohc, p0301
Help with P0301 error on 2001 SL1? LC777 S-Series Tech 13 06-26-2011 08:43 PM
Code p0301 sliprimitive Ion Tech 24 01-31-2011 02:23 PM
Code: P0301 on a 2001 L300 Junkfood L-Series Tech 4 09-08-2010 10:32 PM
p0301 code saturntom1 S-Series Tech 2 02-04-2010 11:59 PM
01 SL2 Code P0301 guzzel S-Series General 8 08-04-2009 07:33 PM
