Old 02-21-2012, 03:35 PM   #1
mkt12a
mkt12a is on a distinguished road
2001 L-Series 2.2L Sedan
Default 2001 L200 Ecotec 2.2L head gasket leak
2001 L200 Ecotec 2.2L with approx. 150K
I am looking for advice on how coolant can find its way into spark plug well on piston 1. So far, coolant looks good and oil looks good but misfiring due to coolant in plug well. Followed a couple of other posts here and found some great tips...pulled off the head and visually see where the gasket let go on firewall side of piston #1. Applied a penetrant and developer to look for minor stress cracks around the plug seat and threads in the head but so far nothing??? Plug was not loose, and was recently replaced thus I thought it had been over torqued. Is it possible for the coolant to go through the threads on the plugs and head and accumulate in the spark plug well? I plan to reinstall the new gasket and head tonight and see if all is good. Is there a good way to detect exhaust gases escaping through the plug besides a little soap and water?
thanks for the help!!!
Mike
mkt12a is offline   Reply With Quote
Old 02-22-2012, 01:14 AM   #2
mkt12a
Default Re: 2001 L200 Ecotec 2.2L head gasket leak
Found crack once I put spark plug into #1 cylinder. Any body have any luck with JB weld or helicoil repairs? Otherwise I am looking for a used head..any idea on cost for a used one?
Old 02-22-2012, 11:33 AM   #3
mkt12a
Dizzy Re: 2001 L200 Ecotec 2.2L head gasket leak
Ok found a decent cylinder head from a 2002 Vue...does anyone know if this head is identical to the 2001 L200 sedan? Price is good at $95
thanks!
2001 L200 2.2 Ecotec engine swap ptabakaru L-Series Tech 2 08-26-2020 11:01 PM
1.9 SOHC Cylinder Head/Head Gasket..... Coolant Leak BRIAN41920 S-Series Tech 12 01-21-2014 03:40 PM
coolant leak...head gasket, cracked head, or water pump? BRIAN41920 S-Series Tech 13 01-11-2013 04:18 PM
Oilpan Removal: 2001 l200 wagon (2.2l ecotec) SumoRerun L-Series Tech 0 01-08-2012 08:26 PM
Is it possible to repair a oil leak from the head gasket without replacing gasket? tgferg67global S-Series Tech 13 12-23-2010 08:39 PM
