Old 04-18-2021, 03:14 PM   #1
lrbraner
lrbraner is a jewel in the roughlrbraner is a jewel in the roughlrbraner is a jewel in the rough
2002 L-Series 3.0L Sedan
2003 L-Series 3.0L Wagon
Default 4 Cyl. Ecotec Oil Pan Gasket.
What is the recommended way to seal the oil pan when reinstalling?
After removing the pan I see little or no sign of sealant.
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 04-18-2021, 06:40 PM   #2
02 LW300
02 LW300's Avatar
Default Re: 4 Cyl. Ecotec Oil Pan Gasket.
Use a high quality silicone gasket maker. I like to use gray since the engine is aluminum.
2002 L200/5 Loaded, over 1/4 million miles!
Old 04-18-2021, 07:54 PM   #3
lrbraner
Thank you for the input.
Do you put a small bead on the inside edge of the pan as i have read ?
Or do you apply it down the middle?
2002 L300 Sedan
2003 LW300 Wagon
2005 L300 Sedan
Old 04-19-2021, 12:20 AM   #4
02 LW300
02 LW300's Avatar
I stay to the inside and go around the bolt holes. Let it cure overnight.
Old 04-19-2021, 12:59 AM   #5
Rj 2000 LS2
Rj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really niceRj 2000 LS2 is just really nice
2000 L-Series 3.0L Sedan
Where do you get this idea to cure gasket maker over night? I recently posted Permatex's video link and directions that explicitly say put the two surfaces you want bonded together while wet, not cured. Do you know something the manufacturer does not?
Personally, I would extend the bead around the center and around each bolt hole (only on one side) and then assemble hand tightening each bolt in normal criss/cross fashion. Allow to cure for an hour and then torque to specs.
IMHO Allowing the gasket maker to cure over night will ensure leaks will occur. If the gasket material is not bonded to each clean surface, it will eventually leak. This is one time I will side with the manufacturer's recommendations.
Old 04-19-2021, 09:18 AM   #6
02 LW300
02 LW300's Avatar
Let it cure after assembly.
05 ion ecotec swap with 07 chevy ecotec spenser4 Ion Tech 7 03-31-2017 12:54 AM
2002 saturn 2.2 ecotec /2010 cobalt 2.2 ecotec dirtydawg Vue Mods 5 07-01-2014 09:20 AM
Valve cover gasket--preventing RTV from bonding to rubber gasket? PlasticCarsRock S-Series Tech 3 09-09-2012 11:38 PM
2001 L200 Ecotec 2.2L head gasket leak mkt12a L-Series Tech 2 02-22-2012 11:33 AM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 03:42 AM
