Old 04-29-2018, 06:57 PM   #1
Adamtheimpaler
Adamtheimpaler is on a distinguished road
Default Any information on Rear Wheel Bearing Assembly Bolt(I snapped one..)
I snapped one of the bearing assembly bolts when I was putting in a new wheel bearing. Does anyone have any information on size or where to buy this for SC1.
I haven't been able to find any info.
I have a 7 minute drive to work. Should be fine with 3 bolts for day or two...right?
Adamtheimpaler is offline   Reply With Quote
Old 04-29-2018, 07:43 PM   #2
Default Re: Any information on Rear Wheel Bearing Assembly Bolt(I snapped one..)
Three should work. It is a metric bolt so you need to measure the diameter at the threads and round up to the whole number in MM. then the length from under the head to the end in MM. Last is the pitch which is the distance in MM betweent the peak of 2 adjacent threads. Look on the head of the broken bolt for the grade stamp, 8.8 or 9.8 most likely.
Wheel Bearing/Hub Assembly; pdorta S-Series Tech 12 09-15-2012 03:38 PM
Wheel Bearing Hub Assembly Question sledgehammer777 Relay Tech 3 03-08-2010 11:45 PM
Wheel Bearing/Hub Assembly-Front/Rear dildog S-Series Tech 3 05-23-2007 11:58 AM
Front Wheel Hub/Bearing Assembly JD7 Ion General 2 06-21-2005 05:52 AM
Wheel Bearing/Hub assembly SLeepr S-Series General 9 08-24-2004 10:23 PM
