Old 08-11-2011, 09:01 PM   #41
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Default Re: Breaking the code
That temp seems real to me on a short drive....5401 is the memory location I have the scangaugeII poll for information. I believe it's a mode 22 request
Old 08-11-2011, 09:05 PM   #42
Redhotftw!
Redhotftw! will become famous soon enough
I would be in love if the fuel tables and map could be cracked to support boost on the PCM
1998 "Red Hot" Sc2
Redhotftw! is offline   Reply With Quote
Old 08-11-2011, 10:32 PM   #43
Thisita
Thisita is on a distinguished road
1996 SC2
Mode 22 == Request_Diag_Data_by_PID 8D
Ok, something you may want to try is to keep pinging "memory" locations, with the y byte set to 01
I'm looking at the code, and it pulls from the buffer, then loads the part of it and cmp's it to 01 Now we are getting somewhere, I'm going to keep tracing from there. The function it jumps into is NOT pretty.
Thisita is offline   Reply With Quote
Old 08-11-2011, 10:45 PM   #44
Thisita
1996 SC2
Some numbers to try for x
$11
$12
$13
$1C
$51
$59
$CF
$F4
There seems to be checking for these numbers
Old 08-11-2011, 10:47 PM   #45
1996SL11.9L
2002 SL1
The scangauge is bydirectional I can look at places, but if the math isn't correct the return is gibberish
I've gone from 00 to 60 so far seeing what's in there....but left the math the same as the temp display request.
Old 08-11-2011, 11:21 PM   #46
The encryption will drive you nuts.
The transaxle temperature is continuously monitored and if hi or low will cause changes in transmission shifting. The ECTS, IAT, And TTS are all compared on a cold start as a operability/accuracy check.
This is why I was thinking of attempting this with the code out of a DOHC manual PCM, less code to deal with.
Old 08-11-2011, 11:36 PM   #47
Thisita
1996 SC2
http://www.fastfieros.com/tech/vpw_c...n_protocol.htm
Great reference for me, it lets me know how the data is formatted without having the docs. Since I know where the base address of serials are, I should be able to kick through the tracing easier now
And yes the encryption will, but it is ok lol
I'm guessing TTS is an auto-only feature?
Old 08-11-2011, 11:48 PM   #48
Yes, the TTS is auto only. With that auto trans dump you have all of the code for operating the autotragic transmission. I am sure it increases the complexity slightly.
I thought I could find a 96-98 DOHC Manual PCM for cheap but so far no luck. Trying to pick all the AT control foo out of the code will be a pain.
Old 08-12-2011, 12:03 AM   #49
TwinRevver
TwinRevver is on a distinguished road
1995 SL2
i wonder if u convert hex into bin then unencryption using Gray code....
i think we have to find what encryption pattern is used to undo this epa bs....
now with problems and getting a newer car but not a saturn :(
My 95 SL2 white top of the line car Priceless..
TwinRevver is offline   Reply With Quote
Old 08-12-2011, 12:23 AM   #50
Data lines swapped. Its hardware.
Old 08-12-2011, 12:31 AM   #51
Thisita
1996 SC2
Packet should look like this being sent:
6C 10 F1 22 xx yy 01
PCM_ID = 10
TOOL_ID = F1 (I need to find the memory location of this)
Mode 22 replies are formed in memory location 383 and can be a total of 9 bytes looking like this
6C F1 10 62 xx yy aa bb cc dd ee
Still need to find the input memory location.
Old 08-12-2011, 12:52 AM   #52
1996SL11.9L
2002 SL1
Yes I sent 6C10F122115401
Old 08-12-2011, 12:24 PM   #53
Thisita
1996 SC2
So the real PID for Tranny Temp is $1154
The cmp I was seeing before, was doing a sanity check on the packet.
Hmmm, can you try sending $119D for BARO in kPa?
I doubt it is the right, but worth a shot.
Old 08-12-2011, 02:34 PM   #54
1996SL11.9L
2002 SL1
Will it be the same math as for the temp?
Old 08-12-2011, 03:16 PM   #55
1996SL11.9L
2002 SL1
I get a 246 for that address but I need to look into what math I'm doing. Am currently using math for knock retard.
Old 08-12-2011, 03:45 PM   #56
1996SL11.9L
2002 SL1
If I put in the math for GM vpw baro at that address I get 738. It's calling it inches of mercury. But the 9d is on scangauge's list for GM baro vpw coms
Old 08-12-2011, 04:26 PM   #57
Thisita
1996 SC2
Hmmm, should be no math, and be in kPa <.< The base system is metric if I remember right. I think OldNuc can confirm on that.
That still doesn't sound like it is it though, was worth a shot, I'll have to check a few more. That was another number that I saw on the internetz
Old 08-12-2011, 04:39 PM   #58
1996SL11.9L
2002 SL1
That is why I had to walk through the addresses looking for trans temp, Internet info was wrong....at least for saturn's.
Old 08-12-2011, 05:54 PM   #59
Saturn is unique except for the small set of FED mandated codes. Makes almost everything you find on the interwebs wrong.
Yes, I think the actual calculations are metric system.
Old 08-13-2011, 08:13 AM   #60
LTond56
LTond56 is on a distinguished road
I have a general question about the process.
Are you using a Datacom Analyzer to record a Tech 2 scanner session?
LTond56 is offline   Reply With Quote
code, pcm, reverse engineering
breaking 14's? Diezeltitan08 S-Series Mods 8 10-22-2010 07:51 PM
Saturn keeps breaking down? Heirophantress S-Series General 29 04-25-2009 10:40 PM
98 SL2 Revs while breaking orlana S-Series Tech 9 01-04-2008 11:30 AM
Breaking in: the EFX spoiler BlueIonDriver Ion General 23 03-11-2004 11:07 PM
Breaking into your Saturn! Whelan General Saturn Discussion 10 12-11-2001 06:25 PM
