Old 04-28-2005, 11:32 AM   #1
Lee3333
Lee3333 is on a distinguished road
Lee3333's Avatar
1999 SW2
Default Engine crank but no start
Yesterday, for the first time, my 93 SL2 gave me a hard time starting. It ususally starts right up-after only 1 or 2 cranks. So I am in the habit of just turning the key for a second and releasing. But yesterday, it coughed but did not start. After that, it would crank but not start. I tried 8 or 9 times, waiting inbetween. Finally, I turned the key and it fired right up. It has been starting fine since then. No warning lights are on, and I had the car checked for codes this morning and there wern't any.
What could it be??? I worry because this is how the trouble began on my 99 SW2, and that turned out to be a bad computer. But, there were codes, many conflicting.
Any ideas?
Lee3333 is offline
Old 04-28-2005, 05:43 PM   #2
Nowhere Man
Nowhere Man is on a distinguished road
Nowhere Man's Avatar
1995 SW2
Default Re: Engine crank but no start
I am no expert on the subject, but it sounds as if your crank position sensor (CPS) has gone bad. The pcm needs the positon of the crank to start and when the sensor stops working, it cant start the car. But it will occasionally start working again, which makes me think it is the cps.
95' SW2
131,000 Miles
32-MPG avg.
Nowhere Man is offline
Old 04-28-2005, 06:37 PM   #3
KatWoman
KatWoman is on a distinguished road
KatWoman's Avatar
Could be your CPS as mentioned above. Other things that could cause this problem could be bad/loose plugs or wires and possibly a bad coil pack, or you could have a air or fuel issue or even a stuck throttle plate (in the throttle body). The first 3 areas to look into with a problem like this are air, fuel and spark.
KatWoman is offline
Old 04-28-2005, 08:08 PM   #4
the_new_raceman
the_new_raceman is on a distinguished road
the_new_raceman's Avatar
I cant agree more!!!! CPS! I would change that sensor 1st before you spend more money that you dont need to. I made that mistake.
the_new_raceman is offline
Old 04-29-2005, 01:19 AM   #5
Lee3333
Lee3333's Avatar
1999 SW2
Where is the CPS? I had the car checked for codes today and there were none. Would this rule out the CPS?
Lee3333 is offline
Old 04-29-2005, 05:02 AM   #6
Mork
Mork is on a distinguished road
If the engine attempted to start (coughed) it may be a sign of a fuel problem.
Either a bad pressure regulator or a failing fuel pump.
Mork is offline
Old 04-29-2005, 02:52 PM   #7
Qlara
Qlara's Avatar
Also it maybe just a minor flood to the engine (Since it won't start the first time, and then keep cranking).
Have an habit to let the Fuel pump primes the system first (simply turn the key to ON, but don't crank yet). You'll hear the pump whine for 5 seconds then stop, you can crank the engine then. It should fire right up.
Qlara is offline
Old 04-29-2005, 07:05 PM   #8
the_new_raceman
The CPS doesnt throw codes but it sometimes allows the enging to start...thats what happened with me. It is at the bottom/back of the engine in a nearly impossible spot to get to above the starter. Make sure the car is SOLID on the jackstands before you climb under there. I also leave the jack on one side just touching the frame incase the stands give away. I cant stress it enough...SAFETY... SOLID STANDS ON SOLID GROUND!!!. If you dont think you can do it safely take it in and have it done. lol can we tell i dont like going under cars?
1999 SL2: Engine won't Start/Won't Crank LoganSan S-Series General 26 12-20-2012 02:25 AM
2000 SL2 Cold Starting Issues [Crank crank crank...] RarestRX S-Series Tech 8 02-12-2012 12:58 PM
no crank no start 04 ION blaisedaddy Ion General 7 06-11-2009 12:33 PM
no crank no start TSB paulo Ion Tech 3 01-29-2009 03:01 PM
96 SL2 Crank but No Start pitch4pd S-Series Tech 18 12-05-2008 09:22 PM
