Old 08-11-2011, 03:56 PM   #1
buniquesl2
buniquesl2 is on a distinguished road
Default 99 SL2 P0304 code......please help
Alrighty, alittle background, i'm new here but not new to Saturns, I love these lil cars. I used to have a 95 sl1, i loved that car i finally blew it up with 210,000 miles on it. That was about 6 years ago. About a month ago I managed to aquire a 99 SL2 with 100k miles and a bad motor for $400 bucks, figuring used engines are pretty cheap it might be a fun little project.
Fast forward 6 weeks, I got a used engine from a 94 sl2, swapped the heads and all the other essentials and dropped it in, everything was going along pretty smoothly until i went to fire it up. It started right up but seemed to be idling pretty rough. While driving it runs great nice and smooth, but when i go back to idle it is rough again. It is showing a P0304 code, and i've been doing hours of research and trial and errors to try to fix the missfire. It has good spark and i've swapped out fuel injectors. When i took the plug out it had a white tip which tells me its running lean.......Ive looked at all the vacuum lines and they all seem ok, most of them are new. I'm at a loss and hope you guys can help me, thanks in advance...
buniquesl2 is offline   Reply With Quote
Old 08-11-2011, 07:30 PM   #2
jim147
jim147 is on a distinguished road
2008 AURA XE
Default Re: 99 SL2 P0304 code......please help
Have you tried a compression test on it.
jim
jim147 is offline   Reply With Quote
Old 08-11-2011, 10:59 PM   #3
buniquesl2
I was just in the middle of doing that test and my compression tester failed...............damn chineese tools What is the compression supposed to be on these cars?
Old 08-11-2011, 11:12 PM   #4
adventureoflink
adventureoflink's Avatar
Bare minimum is 180 PSI.
if you get lower than this, on a warm engine, put a capful of motor oil (the same cap that's used on the bottle) into the offending cylinder and try again.
If it improves, it's a piston ring; otherwise it's valves. Either way below 180 you're looking at surgery.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 08-12-2011, 01:24 AM   #5
buniquesl2
Is there a good number on a cold engine? I only got to do 1 cyl warm but was able to do all 4 while it was cold before my tester broke.
Old 08-12-2011, 08:49 PM   #6
jhonky
jhonky is on a distinguished road
when i got my car looked at for a 303 error code, at one point the mechanic came back and told me he put some oil in each spark plug tube and the 3rd one got dry quick. is that a bad valve or ring?
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
jhonky is offline   Reply With Quote
Need some help with ICM, code P0304 rfortier1796 L-Series Tech 3 08-23-2010 02:34 PM
P0304 Trouble code kj0426 Ion Tech 14 05-17-2010 03:24 PM
P0304 Code and Rough idle USAFAVIATOR S-Series Tech 12 01-12-2010 01:26 PM
Trouble Code P0304 & P0420 thaiwebb S-Series Tech 0 07-07-2008 10:11 AM
P0304 Code (out of ideas) mike_245 S-Series Tech 13 03-13-2008 03:28 AM
