Old 06-13-2007, 02:30 AM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Using synthetic trans fluid, how many miles till the next fluid change?
When using synthetic transmission fluid for a 92 SL2 with a 5 speed trans how many miles is it good for till the next fluid change?
92 SL2, 5 speed
91 Lx 5.0
turbobuick33 is offline   Reply With Quote
Old 06-13-2007, 08:02 AM   #2
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Default Re: Using synthetic trans fluid, how many miles till the next fluid change?
I am changing mine every 30k with Mobil1, which I'm sure is overkill. The regular interval is 100k, so 30-50k would be more than sufficient.
MiSaturn is offline   Reply With Quote
Old 06-13-2007, 08:53 AM   #3
Owners manual says only at 6/7k and then never again. The autos need it every 30k and 100k sounds good to me for a 5spd.
Old 06-13-2007, 10:26 AM   #4
jmd1
jmd1 is on a distinguished road
i work on big trucks. they come with synthetic in trans and diffs. we have them from 500k to 1mil miles. they never get changed. ive seen them run to near empty. fix leak fill up see you later. if you can run atf with 1 change for life of vehicle, i think syn upgrade is good for long time. 100k sounds good.
jmd1 is offline   Reply With Quote
Old 06-13-2007, 11:02 AM   #5
Luke
Luke's Avatar
Fm > Mi Saturn
No rebuttal > that's exactly my schedule
Luke is offline   Reply With Quote
Old 06-13-2007, 03:31 PM   #6
turbobuick33
1992 SL2
How much fluid does the 5 speed trans take?
92 SL2, 5 speed
91 Lx 5.0
Old 06-14-2007, 06:34 AM   #7
BarnOwl
BarnOwl's Avatar
2.5 qts. I believe. As far as the interval goes, at least 100K in a 5-speed. You could never change it and probably not see a difference.
Old 06-14-2007, 07:32 AM   #8
97coupe
97coupe is on a distinguished road
Changing fluid is not a bad idea and can make the difference e between a gearbox that goes 150 or maybe 200 K and one that goes 300K or more. The gearbox is a closed system with no filter and oil does get contaminated with time and only changes will remove it. I go with the 30 to 50K interval(depending on usage, longer if highway miles, short is city miles) Factory guideline are not for longest possible service life because they do want you to buy another car.
97coupe is offline   Reply With Quote
Old 06-14-2007, 01:28 PM   #9
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
When I changed mine at 111,000 miles, it came out clear, thin, and really dirty. I'll probably switch to synthetic after 30,000 and see how it looks when it comes out, and base the next interval off of that. I have a feeling, though, that synthetic should handle the 100k no problem
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
quiksc2 is offline   Reply With Quote
Old 06-14-2007, 01:33 PM   #10
97coupe
It is not whether the oil breaks down and shears out but rather that it gets dirty with time.
Old 06-14-2007, 01:35 PM   #11
S3aturnR
S3aturnR's Avatar
1999 SL1
infinity. don't change it next until you replace your clutch...
s3aturnr
Old 06-14-2007, 02:06 PM   #12
96GSL1
96GSL1 is on a distinguished road
96GSL1's Avatar
1996 SL1
Auto manufactuer's are really lame on transaxle fluid change intervals. The only reasonable ones I've seen (on my cars) is my current Windstar that says to change it every 21,000 (severe) or 30,000 (normal) miles. And that's mainly becuase the tranny's they use are crap, I'm sure.
When I bought my SL1 @ 116k miles, I changed the tranny fluid to a cheap AAP Dex3; and then a few thousand miles later dumped in Mobil 1. The fluid that came out originally, before the cheap AAP oil, was dirrrrty. When I dumped that Mobil 1 30k miles later, it didn't look new anymore either. Not that you can judge a fluid based on visual inspections.
Now it's almost 30k miles again and I'll probalby just change it before wintertime. I did notice improved shifting after using M1. Don't know if I'll pony up the $6/quart for the stuff again but It only uses 2.5 of them I guess.
96 SL1 202k
98 Windstar 123k
96GSL1 is offline   Reply With Quote
'99 Manual Trans Synthetic Fluid Hooter S-Series Tech 4 10-29-2008 10:23 AM
Under $15 Synthetic Trans Fluid Change MiSaturn S-Series Tech 3 05-18-2008 07:47 PM
Synthetic Trans Fluid Problem rlacapra1 S-Series General 4 11-12-2006 08:11 AM
Question - Synthetic Trans Fluid rlacapra1 S-Series Tech 9 09-26-2006 08:18 AM
Synthetic trans fluid DejaVUE Vue General 15 09-23-2004 02:20 AM
