Old 05-02-2008, 04:51 PM   #1
MikeLip
MikeLip is on a distinguished road
Default UN-Modded :) 2006 Ion-2 throwing P0171
Started last night and today the car bucked as I tried to pass on the freeway. Not too happy with that! The car is out of warranty (50K miles, although 2 years old). Had it scanned and P0171 came back.
Incidentally, OnStar is useless. They didn't even give me the scan code when I asked.
The car seems OK unless you push it. Doubt an oxygen sensor, but possibly vaccuum problem? Clues?
Not too happy since two weeks ago I put $400 into "collapsed' control arm bushings! This is my fourth Saturn, and the first to give problems!
MikeLip is offline   Reply With Quote
Old 05-02-2008, 07:57 PM   #2
DukeCitySC2
DukeCitySC2 is on a distinguished road
DukeCitySC2's Avatar
2006 ION-2 Sedan
1993 SC2
Default Re: UN-Modded :) 2006 Ion-2 throwing P0171
Have you looked up P0171? What does that tell you?
Is the Service engine Soon light on constantly?
DukeCitySC2 is offline   Reply With Quote
Old 05-02-2008, 10:15 PM   #3
MikeLip
P0171 according to the Autozone printout means;
Definition; Fuel Trim bank one condition
The computer has recognized a rich or lean condition on one engine bank only.
What is an engine bank? Is that what they're calling cylinders these days?
Probably causes;
1) If bank one and bank two codes set together suspect fuel pressure or MAF. (that doesn't seem to be the case - only one code)
2) Oxygen sensor defective
3) Ignition misfire - repair.
4) Fuel injector problem.
Mike
Old 05-03-2008, 05:03 AM   #4
froggy81500
froggy81500 is on a distinguished road
2006 ION-2 Sedan
Make sure your oil cap is on tight and your dipstick is seated fully. I know it sounds strange, but the ecotec does not use a pcv valve, it purges crankcase pressure internally. If you open the oil cap while the engine is running you will notice the idle fluctuate and you will also hear a sucking sound from the open fill hole. I know this because I just did that the other day and stored the same P0171 code, which is a lean code. Opening the oil cap on a system like this is the same as having a vacuum leak, which would lean out the mix. It could be a bad seal on the cap or stick leaking air also.
And yes the cylinder head would be the equivalent to a bank of cylinders. Obviously on an inline engine there is only one cylinder bank, a V engine would have two banks.
froggy81500 is offline   Reply With Quote
Well, it's official - the '00 is getting modded... Jamin S-Series Mods 13 11-01-2007 05:00 PM
Nicely modded ION Sedan in Classifieds CarNut Ion Mods 6 05-05-2006 12:40 AM
modded ION sedan still for sale urionme03 Classifieds 8 03-26-2006 11:32 PM
modded 03 saturn ion sedan urionme03 Classifieds 19 03-01-2006 12:45 PM
Looking for ION REDLINE video pulling with BMW M3 and modded Z28 on highway chicagomike Ion Red Line 18 08-04-2005 02:05 PM
