Old 09-11-2021, 02:40 PM   #1
dojogube
dojogube is on a distinguished road
Default Trouble starting
2004 Saturn Vue with the 3.5 155K
When starting the vehicle cold, it turns over and over and sputters for about four seconds and finally starts.
Once warm the vehicle starts perfect and runs perfectly otherwise.
Any pointers/suggestions?
dojogube is offline   Reply With Quote
Old 09-11-2021, 03:10 PM   #2
waiter21
2003 VUE 2.2L
Default Re: Trouble starting
Try this:
1) turn the key to ignition for about 5 seconds, (do not try to start).
2) Turn the key OFF for about three seconds.
Repeat this sequence three times, then try to start. Report back what happens...
Old 10-16-2021, 11:56 AM   #3
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Mad Re: Trouble starting
I'm guessing OP solved the problem or is using workaround provided by waiter21 but this thread may show up in future searches so I'll add my 2 cents.
At one time I took care of four family Vue's - 05, 06 and two 07 - all with 3.5 - but fuel tank is similar to all years except 02 and 03 which IIRC had external fuel filters.
I replaced a fuel pump on 07 Vue because the tank check valve stopped checking and let fuel pressure bleed back into tank soon after engine shut down. This led to long crank times and either no or sputtering starts.
The mostly complete story is in following thread but you can fast forward to important information in post 8 of the thread:
http://www.saturnfans.com/forums/sho...d.php?t=216401
IMPORTANT FACT: I've recently noted same fuel pump check valve problem on two other family Vue's - 05 which just rolled over 100,000 miles and 06 with 165,000 miles.
I really hated to drop tanks to change pumps (especially on 05 with AWD) so I tried adding Chevron Techron to fuel tank for a couple of cycles and the check valves in both tanks came back to life!
I'd used Techron in the past to fix a erratic fuel quantity problem so hoped it might lubricate whatever mechanical parts and pieces resided in the check valve and it appears to have done so.
FWIW - I used Techron but I imagine there's any number of fuel tank additives that could get good results.
I visit forum monthly, if at all. Feel free to send private messages if you think I can help. Don't use visitor message as I never check those.
'99 SL2 having trouble starting matchingplaid S-Series Tech 23 03-01-2017 10:58 AM
starting trouble RedlineV6 Vue Tech 2 04-14-2016 09:19 PM
bit of trouble starting jchu210 S-Series Tech 4 05-27-2013 08:12 PM
Trouble starting hit_n_run S-Series Tech 12 04-25-2007 01:43 PM
Trouble Starting.....! 1994SL1 Miscellaneous Tech 2 01-04-2004 12:09 AM
