Old 09-27-2021, 05:52 PM   #1
cobraRed01
cobraRed01 is on a distinguished road
Default 2007 Saturn Vue Hood Ajar Switch Issue
Hi,
My 2007 Saturn Vue Green Line was partially flooded recently. The water never got above 2/3 of the tire height. It has been fully dried out and runs great (so far). All systems appear to be on-line, but the hood ajar switch is intermittently remaining with a check engine. (90% of the time it is showing that it is ajar) No codes are being thrown. Vehicle runs fine regardless.
I did a voltage check on the female connects. I noticed that one was only about 6 volts, but when I moved the wire in the socket, that I was using to connect the multimeter, the voltable jumped up to 12 volts. My questions:
1) Shouldn't that voltage be a constant 12 volts?
2) Can you describe how the voltage should be running through the connector during proper operation?
3) If I simply added a jumper across the connections wouldn't I be able to bypass the switch?
4) Is switch simply and the BCU logic based simply on opening and closing the 12v circuit, or is there a current resistence component the keeps me from jumping the switch.
Thanks!!!!
The hood switch connector image attached is from a Chevy diagram which I believe is the same. It looks identical to the one I am testing and referencing above. Is this not correct?
cobraRed01 is offline   Reply With Quote
Old 10-03-2021, 02:23 AM   #2
cobraRed01
Default Re: 2007 Saturn Vue Hood Ajar Switch Issue
Can anyone provide a solution to this problem?
2007 saturn vue, hood ajar switch
2007 Saturn Ion, gas issue after oil change keith23464 Ion General 9 07-20-2016 02:48 PM
Saturn S-Series Gen 3 Door Ajar/Dome Light Switch SL19302 S-Series Tech 2 01-05-2015 01:09 PM
2007 Saturn VUE A/C Issue aerial_22 Vue Tech 15 08-06-2014 11:33 PM
2007 Ion startig issue (not ignition switch!) James614 Ion Tech 9 04-03-2013 10:21 AM
2009 Saturn Aura- door ajar message and chimes rach Aura General 5 04-28-2011 01:55 AM
