Old 07-26-2021, 11:30 AM   #1
joannapancake
joannapancake is on a distinguished road
Default 2006 Vue Drivers Window Won't Work
This morning, my husband went to roll down the drivers side window only for it to not work. He said that it worked fine yesterday. Any ideas as to what could be wrong? I haven't been able to check to see of there are any sounds coming from the motor because he was on his way to work when he discovered it. Any help is appreciated.
joannapancake is offline   Reply With Quote
Old 07-27-2021, 01:39 PM   #2
Bruce Rock
Bruce Rock is just really niceBruce Rock is just really niceBruce Rock is just really niceBruce Rock is just really nice
2000 SL2
2006 VUE 2.2L
Default Re: 2006 Vue Drivers Window Won't Work
Do the other 3 windows go up and down?
Old 07-27-2021, 09:02 PM   #3
joannapancake
Yes. The others work fine.
Old 07-29-2021, 08:06 PM   #4
ruley73
ruley73's Avatar
Most likely causes are bad window motor or broken wires in driver's door jamb.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone*
2007 Chevy Equinox LT 203K miles
2018 Chrysler Pacifica Touring L 68K miles
Old 07-30-2021, 11:51 AM   #5
jco35
jco35 is on a distinguished road
2005 VUE Red Line
I would check the switch before I would take the door apart. Try swapping the driverside switch for any of the others that you know that are working.
jco35 is offline   Reply With Quote
Old 07-30-2021, 04:21 PM   #6
joannapancake
As soon as my husband gets a day off we will try it. Thank you for your help.
Old 07-31-2021, 02:43 PM   #7
ruley73
ruley73's Avatar
Unfortunately, in this case you can't swap switches to check them. The left side and right side window switches near the shifter are two switches in one. The left front & left rear switches are one piece and the right front & right rear switches are one piece. The connectors are also different so that one can't be connected to the other.
Tags
drivers side, vue 06, window, window motor, window switch
Drivers Auto Window only goes down 1/2 way Demsyter S-Series Tech 0 06-11-2013 09:22 PM
Where is the drivers doors open switch... and why does it not work? burlyvue2 Vue Tech 1 11-30-2005 12:15 AM
Drivers Side wiper not work very well? COME ON IN! TIMSPEED S-Series General 1 11-29-2005 11:16 PM
Broken drivers window satwag S-Series Tech 4 01-04-2005 11:24 AM
drivers side power window wont work sometimes Mike99SC2 S-Series Tech 1 06-25-2001 01:35 PM
