Old 11-12-2016, 02:53 AM   #1
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Default P0301 code...
Turned cold again, so the Silver Surfer tossed me a P0301 code.
Did this last year when it got cold, reset it, tossed some Techron at it,
stayed away until tonight.
Still runs good, code came on just after startup...
Doing wireset and plugs tomorrow,
egr valve is next.
Anyone got hints / suggestions on how to clean the egr?
NGK BKR6E-11 spark plugs
Old 11-12-2016, 09:22 AM   #2
Cheyne
Cheyne has a spectacular aura aboutCheyne has a spectacular aura about
2000 SL2
Default Re: P0301 code...
See the richpin video:
https://www.youtube.com/watch?v=bt5lRTt6BsU
Why those spark plugs?
Cheyne is offline   Reply With Quote
Old 11-12-2016, 09:30 AM   #3
EGR is not likely to cause a 301. Plugs and wires is a better bet.
Old 11-13-2016, 02:20 AM   #4
Saturn Night
Are you getting a high idle, around 1,200-1,300rpms when the engine is warm?
Old 11-13-2016, 06:02 PM   #5
Jim@HiTek
Jim@HiTek has a spectacular aura aboutJim@HiTek has a spectacular aura aboutJim@HiTek has a spectacular aura about
Jim@HiTek's Avatar
2003 L-Series 2.2L Sedan
I just had the P0301 code. It was persistent. Symptoms were mild, but I had 1200 RPM while stopped at a stop light, engine warm.
Checked the plugs...fine. Checked the plug wires...fine.
Replaced the OEM inferior spark coils...no change.
Replaced the ICM...no change.
Sprayed carb cleaner near the cyl #1 intake area...Bingo! RPM dropped a little. So, bad intake manifold gasket.
Replaced it yesterday and the SES light was out shortly after starting and the idle is normal between 750 and 950 RPM. (Took my brother and me 5 hours! But we were also watching a Ducks game and taking our time).
So at least test that intake manifold gasket with spray cleaner first before you buy a bunch of stuff...unless those items need replacing anyway of course.
2003 Saturn L200
DOHC, 2.2L
Luxury Transport
66,000 miles Jan. '21
2001 Saturn SL1
SOHC, 1.9L
Basic Transport
78,000 miles Jan. '21
Jim@HiTek is offline   Reply With Quote
egr, p0301, wireset
2008 vue P0301 code JSTDV8 Vue Tech 25 02-15-2014 02:36 PM
SES light and code P0301 Jerry_Strn S-Series General 14 03-21-2011 09:47 AM
Code p0301 sliprimitive Ion Tech 24 01-31-2011 02:23 PM
p0301 code saturntom1 S-Series Tech 2 02-04-2010 11:59 PM
01 SL2 Code P0301 guzzel S-Series General 8 08-04-2009 07:33 PM
