Old 03-25-2007, 02:02 AM   #1
jess3292
jess3292 is on a distinguished road
2003 ION-3 Sedan
Default Need Help Find O2 Sensor Under Hood - 2003 Ion
I need help finding the O2 (front or first) sensor that is before the catalytic converter...I bought a new one today and want to install it but cannot find where it is on my engine...Please be descriptive in how to find it, I am kind of new to this stuff....a picture would even be better if at all possible...
I have a 2003 ION by the way.....
Many thanks in advance!!!!!
JESS
jess3292 is offline   Reply With Quote
Old 03-25-2007, 10:10 PM   #2
ScottKilpatrick
ScottKilpatrick is on a distinguished road
ScottKilpatrick's Avatar
2007 ION Red Line
2007 VUE Red Line
Default Re: Need Help Find O2 Sensor Under Hood - 2003 Ion
It's not in the engine. look under the car at your exhaust pipe just before the cat and after the downpipe. you will see the O2 sensor sticking out of the side of the pipe.
'07 ION Redline onyx black w/comp. package
245whp, 231wtq
WAY too many mods to list!
ScottKilpatrick is offline   Reply With Quote
Old 03-26-2007, 12:41 AM   #3
The bank one HO2S on the ION engine is in the exhaust manifold. You will need to remove the heat shield one the manifold and you will see it. It is one the drivers side just before the manifold to pipe joint.
Old 03-26-2007, 07:17 AM   #4
kaviation
kaviation has a spectacular aura aboutkaviation has a spectacular aura aboutkaviation has a spectacular aura about
kaviation's Avatar
2003 ION-2 Quad Coupe
JESS
What is the reason you are changing it?
2003 Ion QC- Sold August of 2015
2004 Ion Redline
Meth Injection, WOT Box, Fidanza aluminum Flywheel, GMPP clutch,
Ported/Polished S/C FE5/YYZ suspension upgrade with FE5 Aluminum LCA's
kaviation is offline   Reply With Quote
Old 03-26-2007, 03:51 PM   #5
jess3292
2003 ION-3 Sedan
I got a few codes off the car indicating it might be starting to fail....
My mileage is way off and my performance is not good either....
Just wondering from the descriptions above if this is something I can do myself - does the car have to be on a lift to replace the sensor????
Old 03-29-2007, 03:03 PM   #6
teebird
teebird is on a distinguished road
Replaced mine at 80k miles because it was throwing a code. Could also smell the exhaust. You can do it yourself. You have to remove the heat shield. Remove the connector. You'll need the special O2 socket. Fairly easy.
teebird is offline   Reply With Quote
Old 02-21-2015, 06:32 PM   #7
bonesjrf
bonesjrf is on a distinguished road
I found it easy. Stand in front of engine reach toward firewall. (make sure engine is cold or cool) its right on the exhaust pipe. With 2 wires coming off of the sensor. This is the up stream O2 sensor. The down stream on is under the car on the exhaust pipe. This is easy to get to. Passanger side easy way to get to it. I found out that if you replace one it is better to replace the other one at the same time.
bonesjrf is offline   Reply With Quote
Help With Oxygen Sensor - 2003 Ion jess3292 Ion General 5 02-17-2007 12:58 AM
2003 saturn ion hood release problem north52ice Ion General 2 12-09-2006 11:49 AM
Getting the hood open on my 2003? daily Vue General 9 03-11-2006 11:58 AM
Can't find Universal O2 Sensor for '93 SL2 Leadsled Coupe S-Series General 9 11-11-2005 09:49 PM
trying to find a ram air hood srcauto rlvue Vue Red Line 23 03-14-2005 02:11 PM
