Old 10-28-2014, 04:34 PM   #1
Keico
Keico is on a distinguished road
Default Driver side rear door will not open
Ok I have a 2005 Saturn Vue 2.2L
The door behind the driver side occasionally would not open.
Now it is at the point it will not open at all.
I am stick as what to do to fix this.
Please help.
Keico is offline   Reply With Quote
Old 10-29-2014, 01:15 AM   #2
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2006 ION-2 Sedan
Default Re: Driver side rear door will not open
Step 1) buy a new latch
Step 2) break the old latch.
Ok it's been pretty long time since I've done one so look at
http://www.saturnfans.com/forums/sho...highlight=door
Old 10-29-2014, 12:53 PM   #3
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
Originally Posted by suzaan View Post
Sounds like you're on the right track to me. If both door handles won't open the door, the mechanism must be jammed or broken and the only way in is through the door panel.
Had difficulty for 2 years getting out. The plastic piece you pull on wears out on the inside. A rod fits onto a plastic piece which rides inside a kidney shaped hole. The hole gets longer from wear. I had local SASP replace both pieces. When pulled on about 3/4 inches opens right up.
JefferyC is offline   Reply With Quote
Back Driver side door won't open all the way wendyhmily Ion General 1 02-07-2014 10:50 AM
03 VUE rear driver door won't open 03satvue Vue Tech 2 03-04-2012 07:09 AM
93 SW1 driver's side front door won't open Hewjerome S-Series Tech 4 02-26-2011 09:38 PM
Help can't get driver's side door open! Lurker1999 S-Series Tech 6 12-28-2004 02:41 PM
Driver side door wont open. Hollowsend Miscellaneous Tech 1 10-14-2000 06:34 AM
