Old 06-17-2006, 04:14 PM   #1
gregoryblock
gregoryblock is on a distinguished road
2003 ION-1 Sedan
Default Mysterious no-start problem
Hi Saturn Forum,
Living in New Orleans, and its getting quite hot down here. It seems to be escalating this strange problem I've been having that Saturn dealers everywhere can seem to diagnose. My car won't start when its hot. This started only after long drives; when I stopped for gas, my car would not start. Now, with the heat is seems to be happening more often. If I leave it until it cools, the car starts fine. Usually, I open the hood and try start it once a minute, for about 10-15 minutes and then it starts.
Here are some clues that may help any of you tech gurus:
1) The car does turn over sometime, but then shuts down
2) The battery is fine.
3) It helps if I pump the gas pedal
4) It doesn't help if I turn the A/C off when I shut down the car
5) It DOES help if, after a long drive, I let the car idle, until the engine fan turns off (I'm not sure thats actually what its doing, but if I let it sit, the revving of the engine eventually calms down. Each time I have done that, I think I've given the engine some time to cool, and I never have a no start afterwards.
I hope you chaps can help; this is getting ridiculous! I know that the car will crap out on our first hurricane evacuation!
Thank you kindly,
Greg
gregoryblock is offline   Reply With Quote
Old 06-17-2006, 04:53 PM   #2
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
Default Re: Mysterious no-start problem
bad injectors?
06_Ion2 is offline   Reply With Quote
Old 06-18-2006, 04:30 PM   #3
gregoryblock
2003 ION-1 Sedan
Checked that, apparently the injectors are OK. I will double check with them again?
G
Old 06-18-2006, 04:35 PM   #4
dcfatalis100
dcfatalis100 is on a distinguished road
1991 Astra XE
1991 AURA XR
Spark Plugs
or
Ignition Switch.
dcfatalis100 is offline   Reply With Quote
Old 06-18-2006, 04:41 PM   #5
TEX
TEX is on a distinguished road
1996 SL1
Have you had the starter checked?
TEX is offline   Reply With Quote
Old 06-18-2006, 04:55 PM   #6
Bigdaddy94sc2
Bigdaddy94sc2 is on a distinguished road
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
2005 VUE 3.5L
Ignition control module
Due to the heat issue stated, leads me to believe it is that.....
GM, Saturn, and ASE certified Technician. Always glad to try to help, just ask!!! Now own an 06 ION.2 as of 7/2/06 with 2988 and counting (7/28/06) 13131 as of (1/8/07) 24901 as of (7/30/07)
Bigdaddy94sc2 is offline   Reply With Quote
Old 06-18-2006, 06:09 PM   #7
gregoryblock
2003 ION-1 Sedan
Yes, the starter appears to be fine . . . ignition control module, I will ask them to look @ as well. Just got a suggestion that it may be the grease inside the ignition switch overheating?
I'll print off all your suggestions and take them to the mechanic . . .thanks!
Old 06-19-2006, 11:32 PM   #8
Crank position sensor; similar heat related issue as the ignition control module.
Old 06-21-2006, 03:54 AM   #9
Bigdaddy94sc2
2006 ION-2 Sedan
2005 VUE 3.5L
The grease in the ignition switch is USUALLY a major problem in colder temps, not hotter ones. Not saying it isnt possible, but not likely.
Old 06-21-2006, 06:42 PM   #10
teebird
teebird is on a distinguished road
Vapor lock??? Not usually a problem on the fuel injected vehicles, but it is possible.
teebird is offline   Reply With Quote
Old 06-22-2006, 10:10 AM   #11
gregoryblock
2003 ION-1 Sedan
Ok,
So after a painstaking day at the saturn dealer, watching them run around like chickens with their heads cut off, they concluded (after a 200 buck diagnosis fee) that they can't find any problem with the car. The tech, who they will not allow me to communicate with, wants to replace the ignition cylinder. I've found nothing online that suggests this could be the problem. What do y'all think?? I'm not too keen on these guys throwing parts at me . . . starving student you know?
G
Old 07-06-2006, 02:34 PM   #12
dbroyl01
dbroyl01 is on a distinguished road
dbroyl01's Avatar
1996 SL1
2003 ION-3 Sedan
Greg,
When it is acting up, have you tried wiggling the shifter (Automatic shift console) and pressing the button on the shifter a few times until you hear the electronic switch behind the dash go "click"? I may have the same problem.
dbroyl01 is offline   Reply With Quote
Old 07-06-2006, 03:18 PM   #13
Gerry Proctor
Gerry Proctor has a spectacular aura aboutGerry Proctor has a spectacular aura about
2008 Astra XR
2008 SKY Red Line
It would probably be the ignition module or the crank position sensor. It could also be leaking injectors. Or, gulp, the coolant temp sensor. If the sensors and module are working when tested, then they are working as advertised as far as the tech is concerned. It a matter of testing things when you are having a problem. If the crank position is reading you should see the tach registering about 200 rpm when cranking even if it doesn't start.
Gerry Proctor is offline   Reply With Quote
Mysterious L200 problem HELP!!!! Jennifer L-Series General 3 07-16-2009 02:46 PM
no start problem BlackBirdRacing S-Series Tech 6 02-10-2007 11:28 PM
Mysterious problem, is it the BCM? 1stSaturnowner L-Series Tech 10 05-30-2006 10:04 PM
Mysterious problem for techs... xFan S-Series Tech 14 03-03-2004 11:49 PM
No Start Problem silverplum General Saturn Discussion 17 08-10-2001 02:14 PM
