Old 04-07-2011, 10:29 PM   #1
tweak
tweak is on a distinguished road
Default 2008 Saturn XE coolant leak?
Hi guys,
Have an 08 outlook. The coolant reservoir is empty but radiator has coolant in it (i can see it down there). Pressure test came back nothing. Topped off reservoir 2 days ago and it's empty again Any suggestions? Thought maybe it had an air pocket or something but I can't find out how to bleed it.
Thanks
tweak is offline   Reply With Quote
Old 04-14-2011, 03:58 PM   #2
ohioy2kxj
ohioy2kxj is on a distinguished road
Default Re: 2008 Saturn XE coolant leak?
I am having the same issues. But I am seeing coolant occationally dripping on the driveway. Appears the water pump is leaking, but I am having a hard time telling for sure with the way it is buried in the engine compartment. I am at 52K miles
ohioy2kxj is offline   Reply With Quote
Old 04-14-2011, 06:54 PM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
good thing is if it is water pump, head gasket or something serious warranty will cover it as long as under 100k miles...
Old 07-02-2012, 02:01 AM   #4
jcarm
jcarm is on a distinguished road
I know this is an old thread, but I had my water pump fail at 38k miles on my 2009 Outlook. One warning sign it was leakin was that the engine fan would stay on after I turned off the vehicle. Didnt notice the leak till I was about to wash my car a few days later. Passenger side near tire is where the leak was dripping to. Got under car with a flashlight and checked the hoses around the engine block. Finally found that the leak was comming from the water pump. It was fixed under warranty.
jcarm is offline   Reply With Quote
Old 09-13-2021, 02:19 PM   #5
Nursetom
Nursetom is on a distinguished road
Anybody pull and replace the water pump? Having the same issues, trying to see where its coming from; front (passenger) side of the engine, coolant running from ? and dripping off the oil pan just behind the mainshaft pully. How hard a job is the WP?
Nursetom is offline   Reply With Quote
Old 09-25-2021, 02:19 PM   #6
Doug C
Doug C's Avatar
2008 Outlook XE
Attention Re: 2008 Saturn XE coolant leak?
Had similar problem 3 yrs ago.
'My' garage did a pressure test which came back negative. But reservoir emptied again, although I was prepared with on board container of 50/50. And noticed (too much) moisture on cardboard under vehicle in it's garage spot.
Back again to garage, where some indication of moisture on bottom of WP.
So decided to okay them replacing WP.
After a couple weeks and another 3000km trip, reservoir settled down (air bubbles finally purged from sys, post-op'), and has held at appropriate level.
2002 Saturn SL2 Ghost Coolant Leak peach_eater S-Series Tech 34 09-03-2020 10:41 PM
tips on fixing a sl2 2000 saturn, with a coolant leak, near the right front tire grinthenbearit S-Series Tech 9 10-07-2008 06:22 AM
coolant leak saturn LS1 marshman L-Series Tech 6 03-13-2007 08:26 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 12:56 PM
1998 saturn sl coolant leak saturndog Miscellaneous Tech 6 08-09-2004 09:09 PM
