Old 02-12-2007, 09:48 PM   #1
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Default auxiliary jack
My dad has a 2002 LS2. It has the stock stereo with the 6 disk changer built in. There is a button on the front that says AUX. In the back of the stereo, is there an input for 1/8" jack or RCA inputs? My dad wants to plug his MP3 player in.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
quiksc2 is offline   Reply With Quote
Old 02-12-2007, 09:56 PM   #2
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default Re: auxiliary jack
Try it, it can't hurt anything.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
lostwages_ls2 is offline   Reply With Quote
Old 02-12-2007, 10:03 PM   #3
quiksc2
quiksc2's Avatar
Ya, it's just that the stereo isn't as easy to pull out to look at the back like the one in my Sc2. I would like to know ahead of time if there is no input so I don't waste my time pulling the stereo out.
DCS
Old 02-12-2007, 11:17 PM   #4
beensmoked
beensmoked will become famous soon enough
2001 L-Series 3.0L Sedan
2002 L-Series 2.2L Sedan
look on ebay for that same exact radio and see if u can find a rear view
beensmoked is offline   Reply With Quote
Old 02-12-2007, 11:19 PM   #5
beensmoked
the AUX is just for the CD player
Old 02-13-2007, 04:15 AM   #6
quiksc2
quiksc2's Avatar
What do you mean just for the CD player?
DCS
Old 02-13-2007, 07:57 AM   #7
beensmoked
the 6 disc changer for the L series doens' have a CD/TAPE button like the normal double din single disc player. They called it the AUX instead. I don't know why
Old 02-13-2007, 10:24 AM   #8
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
If it's just an input, then it is sending the signal to the amplifier. So the jack should work with an Mp3 player.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
unkle bik is offline   Reply With Quote
Old 02-13-2007, 10:29 AM   #9
tackepj
tackepj will become famous soon enough
tackepj's Avatar
2008 Astra XE
Yep. I wired a friend's civic for his ipod through the RCA input normally used for the CD player (it's a separate unit in certain Hondas).
tackepj is offline   Reply With Quote
Old 02-14-2007, 02:45 AM   #10
quiksc2
quiksc2's Avatar
No, there's a tape/cd button on the stereo. It has the disc changer built in to the deck. When I push the aux button, nothing happens, so I was thinking maybe a signal had to be going through it to switch over. I guess I will just pull it out and see. Does anyone have directions for pulling the stereo out?
DCS
Old 02-14-2007, 08:08 AM   #11
beensmoked
it looks like this right?
http://media.mainstreetcommerce.com/...e-1b7c5d205545
Old 02-14-2007, 08:58 AM   #12
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Pop the trim bezel of by squeezing it toward the center.
When that comes off, you will see 2 metric hex bolts holding the unit in. (7mm, IIRC). The unit should slide out. Try not to remove the harness unless you want to reset everything
Do a search and you should find more detailed info.
Hope this helps.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 02-14-2007, 03:59 PM   #13
markymarkmark12
markymarkmark12 is on a distinguished road
Idea Re: auxiliary jack
i also have a 2002 L200 sedan with a 6 disc changer though i also have a dvd system...when i'm tryin to go from anything else(radio, tape, dvd) back to the cd player i push the aux button...though i dont know if there's a connection on the back of the cd player, your father should get a power plug and an adapter for the ipod, they cost around 20 for the power plug(it plugs into the aux. power outlet, or cig. lighter) and they make two different types of adapters, 1) its like the tape deck adapter for a discman(usually around 10 dollars) or 2) it tunes into an unused radio station on the radio(depending on the model range from 15 up to over 100 dollars)...this is what we had to do to my roommates old car so he could listen to his ipod in the car
markymarkmark12 is offline   Reply With Quote
Old 02-14-2007, 09:54 PM   #14
quiksc2
quiksc2's Avatar
I work at Radio Shack, and sell both of those. The last thing my dad needs is wires going everywhere, and more things to have to mess with. I'll pop the radio out and see what I can do.
DCS
Old 03-23-2007, 06:39 AM   #15
lambdapro
lambdapro is on a distinguished road
2004 L-Series 3.0L Wagon
2007 AURA XE
Did you ever find out if the auxiliary jack in the back works on that ipod? I would like to hook up that way as well.
David
lambdapro is offline   Reply With Quote
Old 03-23-2007, 10:05 AM   #16
PaulGraz
PaulGraz is a name known to allPaulGraz is a name known to allPaulGraz is a name known to allPaulGraz is a name known to allPaulGraz is a name known to allPaulGraz is a name known to all
PaulGraz's Avatar
2001 L-Series 2.2L Wagon
You probably need an interface to plug in anything other than the factory changer into that aux jack. Maybe Blitzsafe makes one...
PaulGraz is offline   Reply With Quote
jack stands and floor jack jonny772 Ion General 26 01-13-2019 09:36 PM
Auxiliary Input on Radio videodad Relay Tech 6 10-20-2009 04:56 PM
'02 Single Disc Headunit Auxiliary Jack? boomer359 S-Series General 2 08-27-2006 08:50 PM
Where to put jack stands and jack up a 1996 SL2 almies S-Series General 2 10-25-2005 03:13 PM
OEM auxiliary input cary Miscellaneous Tech 0 04-13-2003 03:35 PM
