Old 07-03-2018, 09:15 PM   #1
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Default Greasing shifter...
Shifter is a little tight, what grease do I use?
This is underneath the gearshift knob...
White lithium grease?
Many Thanks
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 07-04-2018, 10:40 AM   #2
Signmaster
Default Re: Greasing shifter...
That's what I've used. You could probably use the heavier stuff if you want since the area is protected from the worst dust and crap.
Old 07-04-2018, 05:07 PM   #3
00_SL1
00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough00_SL1 is a jewel in the rough
00_SL1's Avatar
2001 SL2
How about some dry graphite, like what comes with the eBay replacement shift bushing?
01 SL2
04 Silverado
06 Uplander
05 Express
00_SL1 is offline   Reply With Quote
Tags
grease, shifter, tight
Tie Rod end greasing question ampecsu S-Series Tech 7 10-14-2017 10:35 PM
Window Regulator greasing simkid5614 S-Series Tech 4 11-01-2011 11:22 PM
greasing outer tie rod ends quantumech S-Series Tech 4 08-31-2009 01:02 AM
"Greasing" a window Atrocity S-Series General 6 03-16-2007 09:35 AM
Greasing the sunroof Petey S-Series Tech 9 04-29-2004 08:59 PM
