#21 | |
![]() Join Date: Dec 2021
2001 SL
#22 | |
2001 SL
#23 |
2001 SL
I went with a Stant 14279 thermostat from rock auto and it came w/ the housing. so that should be all good. I would expect a slight drop in fuel mileage during the cold months (i live in Connecticut, USA) but definitely not all the way down to 15 mpg. the tire pressure is good. Not sure what to do. any ideas?
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
Have you read the sticky?
http://www.saturnfans.com/forums/sho...d.php?t=177672 I'd check for vacuum leaks if you have not already. Quote:
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#25 |
2001 SL
So on my way home from work today. It started hesitating again and the temperature was back to a little above 1/4 again. The only thing I did was add coolant because I thought it was low. When I got home I drained some coolant because maybe I added to much. So hopefully the hesitation goes away now that I’ve taken away some coolant? Very weird
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
How many miles on your SL SOHC? How long have you had it and what was the mileage when acquired?
Check for vacuum leaks as I mentioned this morning and Waiex mentioned this afternoon. Check both the vacuum lines and the intake manifold gasket. Something is off with the coolant temperature situation reading too high and now too low after you replaced the thermostat. You've already replaced the ECTS so look at the ECTS connector again and answer these questions...
Loss of power will also happen with a clogged pre-cat attached to your exhaust manifold or a clogged catalytic converter. If you run the car too rich for an extended period these components get clogged with carbon deposits. How does the exhaust smell? Any unburnt fuel smells? .
1999 SL2 MT (299,400 km @ 11/2021) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: |
#27 |
2001 SL
So just before I was about to come on here and say my problem was all fixed. i was driving home yesterday and my temp gage went back to in between 1/4 and 1/2 (see picture) and my fuel mileage is back to being very bad. I can get an exact number tomorrow when I calculate it. the hesitation when accelerating isnt nearly as bad but it stated to come back once and that was it. it seemed like replacing the thermostat fixed the hesitation and the fuel mileage eventually went back to normal but then the problem came back. could the stant thermostat already be failing??? any ideas?
#29 |
Check out my post:
http://www.saturnfans.com/forums/sho...&postcount=128 I think you said the ECT connector was good, but did you inspect it closely? Mine stopped working a day after after I changed my ECT and I took a closer look.
#30 |
2001 SL
Waiex191 i did and it was not corroded like that at all. ill double check but no green or any other rust was present. i think the ECTS was probably fine t o be honest because it was not cracked or anything but I still replaced it because of what was said about it failing eventually.
i dont know if i wasnt to just throw a new connector on there just because if i think its working properly. is there anyway to test it with a voltmeter? |
#31 | |
Your earlier picture seemed high and that is why I asked if you could take a reading using a scanner with live data capabilities. I though maybe your gauge calibration was off. My last post had a bunch of questions that haven't been answered.
#32 |
![]() ![]() Join Date: May 2004
Given the misfire code (initially), I'd check all the spark plugs, and verify
that they are the conventional style (Not fine-wire platinum). On both my '97 and 2000, I've discovered small flakes of carbon across the gap, causing shorts. This is rare, and generally accompanies other issues... but if there are fuel consumption issues, it is helpful to cover all the bases, and do fundamental blocking/tackling on the basics. ... There ought not be misfires just months after new plugs+wires; possibly the 'spark' is weak, or the IgCtl Module is out of sorts. The appearance of each plug will reflect the conditions within that cylinder. * * You - cplvan - remarked that you added coolant, AND the engine temperature is varying. That may indicate "bad coolant" issues, which may be affecting the head gasket composition. Have you removed the coolant from the block, and FLUSHED out the block yet?? The original factory coolant was the pink-colored 'DexCool', which was found to be very good in many vehicles. However, in Saturn cars, the Dexcool, after some years (and, notably, If the coolant level is allowed to decline) becomes ACIDIC, and dissolves some of the head gasket material. Soooo, a good practice is to remove the thermostat, fully drain the coolant, monitoring its color (green or pink... or green becoming pink while draining). Then, fill the block with purified water (distilled, de-ionized, or Reverse Osmosis), run engine without thermostat for 5 minutes, and drain coolant, monitoring color. If the color is other than pale green, repeat with another 5-minute flush with purified water, and drain again. Then, install thermostat, add 1 full gallon of (fresh-New) green prestone antifreeze, and top off with Purified water. That would require 2gal + 2gal + 1gal == 5 gallons purified water = $5. Better practice involves addition of an ounce/tablespoon/shotglass of electric dishwasher detergent to the initial flushing mixture (suggested in the OEM/Helm Factory Service Manual. After you top off reservoir with purified water ... add 2 GM 'Cooling System Tablets' for aluminum block engines, available at Cadilac &/or Chevy dealerships for ~$5-$7. After running the engine for an hour or two, may need add a little more water to just below level of horizontal seam in plastic reservoir. * * After which, resume troubleshooting. Last edited by TomM96; 12-17-2021 at 07:00 PM. Reason: fergat un |
#33 | |
2001 SL
No it doesn’t look like the connector has been replaced before and there no coolant residue or dirt on the connector pins. It does feel like there is a bit of a loss of power. The exhaust smells fine. No unburnt fuel smells. |
#34 | |
2001 SL
#35 | |
Check this out. It's easy.
https://youtu.be/9CPqbaSgcok Quote:
#36 |
![]() ![]() ![]() Join Date: Oct 2017
1994 SL2
On engines with a Mass Airflow Meter, a vacuum leak causes problems because THAT air doesn't go through the meter and doesn't get computed in the calculations used to inject fuel into the engine.
But on engines without the MAF sensor ( this is called speed density type), there's no actual measurement of the air getting into the engine. The air volume is calculated based on Air Temperature, Vacuum, and RPM. So, a vacuum leak doesn't have the impact on this type of engine control as the Mass Airflow type. Thus, unless you have a MASSIVE vacuum leak (which you'd hear), I seriously doubt that a vacuum leak is the problem. I think your problems are more likely an O2 sensor failure (Bank 1 sensor 1)(sensor 2 wont cause running issues), or a plugged up catalytic convertor. PLUS, the Engine Coolant Temperature Sensor, ECT, plays a major roll in the calculations that the Saturn computer does. Thus a bad ECT can cause ALL KINDS OF PROBLEMS. The thermostat isn't as important yet, because the engine will run 'Ok' with the thermostat open. I believe that reason that the ECT impacts the Saturn so much is because the engine is so small. So the problem appears more intense on this small engine. So, the first thing to do is the ECT replacement. It's cheap. Next step, remove the O2 sensor and see if the engine runs better with the hole open, thus less back pressure. If it runs better, it's likely a plugged up catalytic convertor. Otherwise, replace the O2 sensor and go from there. Fuel pressure could be an issue as well. And of course, while you're polking around under the hood, tighten up the vacuum hoses, clean the port under the MAP sensor, clean the throttle body, and verify that the hose to the fuel pressure regulator is intact and correct. You might even check the ports under the EGR valve, and the valve itself. These items will make the engine run smoother and idle with less vibration. But they wont necessarily cause drivability issues like you mention. Preston |
#37 |
I'm going to call the ECTS, ECTS connector and thermostat as all being good based on your actions and responses. The last gauge reading is what I would expect and the only thing additional you can do is take a live reading to confirm the temp is approximately 193. Your root cause has been resolved with the exception of a possible vacuum leak. Waiex191 has got you covered with the video. Let us know if this is confirmed and subsequently fixed.
With all that said I think now you are looking at the problems caused by the previous owner (and yourself since ownership) running the engine too rich for an extended amount of time (because of failed thermostat). As mentioned it creates a lot of carbon deposits within the throttle body, EGR valve, engine, exhaust manifold, air injection system, pre-cat, oxygen sensor and catalytic converter. You need to clean this up to restore air and exhaust flow. Everything but the catalytic converter, oxygen sensor and possibly the EGR valve (if pintle movement can't be restored) involves just labour. I'd start with throttle body, egr and the air injection system manifold tube. As mentioned you can also temporarily remove the O2 sensor and take a test drive to see if there is a downstream exhaust restriction (plugged catalytic converter). As you work through this methodically you will determine what is causing the power loss.
Tags |
bucking, hesitant acceleration, poor gas mileage |
1998 SC2 hesitation when accelerating | jerseyjim119 | S-Series General | 24 | 10-17-2011 08:57 PM |
2004 v6 awd with a P0131 code | Blackbeauty | Vue Tech | 3 | 02-08-2007 06:27 PM |
96' SL2 with Hesitation when accelerating | Nickdfresh | L-Series General | 2 | 07-26-2006 06:45 PM |
Hesitation when accelerating | EricSL98 | S-Series Tech | 18 | 09-02-2003 09:27 PM |
Hesitation when accelerating | IoninSA | Ion General | 41 | 07-23-2003 01:24 PM |
