Old 08-24-2005, 08:35 AM   #1
Vertigoomg
Vertigoomg is on a distinguished road
Vertigoomg's Avatar
Default P0300
That's what I'm getting at redline in my 97 SC2 with a computer from a donor car with power windows, power locks, abs, and traction control. I'm going to try to get a computer from a car exactly like mine except manual: no PL, PW, ABS, or TCS. The Service light is always on, and the SES light flashes at redline. Thanks to my handy pocket scanner, I can check the codes on the fly. As soon as I shift... and a few moments later, it goes away.
Some other important info:
I have *GASP* Bosch Platinum +4's with Bosch wires. AFAIK, the *******s are going to be gone ASAP. However, I have fear that the computer won't compensate for the lack of resistor plugs or wires. Is that the reason it's misfiring? I don't wanna blow my motor...
Also, for those who noticed the loose bumper issue, IT'S BEEN FIXED! My dad and I are currently working on fixing the thing that keeps the fender in place and absorbs low speed collisions. Unfortunately, removing the dent won't be too easy. If the bumper and fender will match up, however, that'll be enough for me. The dent will be a reminder of the sacrifice I took (or, rather, Tori took) when I bumped my friend's fat ass of a car out of the mud. (Inside joke )
Also, I'm getting bad gas mileage on the MP3. Tell me either A. Possibility B. Definitely not or C. Wouldn't happen and 1. Big factor or 2. Small factor:
Misfiring
Faulty return system
Those damn Bosch ****s
Bumper hanging (aerodynamics )
Allignment (Haven't done it since the swap, will do soon)
Bad battery, meaning more alternator activity
Bad A/C clutch
Just having A/C on way too much
Any of the other pulleys being bad
My ****ty ass shifting
Not having fender guards, splash guard, and deflector
Bad PCM
I'll try these first. I want to opt for an MP2, as I would like to have the wider ratio gears.
Vertigoomg is offline   Reply With Quote
Old 08-24-2005, 11:36 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: P0300
P0300 misfire means either you have bad spark plugs, bad spark plug wires, bad ignition coils. start with the plugs, get rid of the platnums and get some plain old NGK plugs. disconnect the battery before you change them. if new plugs don't help, get new wires, if that still doesn't help get new ignition coils, if that doesn't help you may need a new ignition module which comes with coils on it.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 08-25-2005, 11:51 AM   #3
Vertigoomg
Vertigoomg's Avatar
Default Re: P0300
Thanks a LOT. I'm dropping the plats, double time!!! They are already going bad (after two fuel changes!!!!). **** plats, man. They may run for some but not for me!
p0300 rj59 S-Series General 11 02-10-2009 01:49 PM
P0341 and P0300 - Help mgordon1100 S-Series Tech 5 07-18-2007 02:42 PM
Suggestions for a P0300 RangerRover S-Series Tech 1 04-25-2007 06:20 AM
Help if you can code p0300 dec29p Ion Tech 8 02-06-2007 11:21 PM
P0300 - What to do next? BarnOwl S-Series Tech 7 09-14-2005 07:32 AM
