#1 |
![]() Join Date: Dec 2014
2007 AURA XR
Hey I have a Aura with about 232k miles. I just get a P0300 and i notice i have a rough idle but it starts up fine and when i am on the highway it keeps up speed fine. Everything seems to be running good. I am wondering do you think it just time for me to change the spark plugs? I am also wondering if it was the spark plugs wouldnt it be a certain cylinder instead of a random? I am also not sure when the plugs been changed because i got the car used.
#2 |
![]() ![]() ![]() Join Date: Aug 2012
SOunds like a great opportunity to change them... and all fluids and filters...
'05 ,2.2L, FWD,5-speed stick with transaxle death rattle is history,,, '17 Suby Forester 245216 mi. VUe is off to the dealer auction I'm a secondhand vegetarian. Cows eat grass, I eat cows. |
#3 |
2007 AURA XR
Fluids have been changed. But it is getting close to do a oil change. I dont think that could be causing it.
But you think if i change the plugs that should fix it? |
#4 |
If you have your owner's manual, check for maintenance intervals in regards to replacing spark plugs. Most Saturns have platinum plugs good for 100k miles unless an owner's manual specifies less. If no owner's manual, try here; http://www.saturn.com/owners/owner_r...s/manuals.html
#5 | |
2007 AURA XR
![]() Quote:
#6 |
While color is only one factor in determining plug wear, other factors need to be considered such as mileage and type of plug. Normal plugs should show tan coloring. White can be interpreted as lean fuel mixtures unless they're relatively new. New plugs have sharp edges on side electrodes with very little combustion deposits anywhere. Worn plugs will show side and center electrode wear as rounded edges and a larger gap than specified. These descriptions are termed as plug reading, similar to palm reading but based on science from past history of engine running and various plugs. If in doubt, replace spark plugs and stay with recommended stock plugs.
O2 sensors have no real expiration date whether using mileage or time. As an electronic component designed for long life, some fail prematurely while others last the life of an engine so a median life expectancy is recommended. Most O2 sensor replacements are from troubleshooting using error codes and/or hard diagnosis along with symptoms. I cannot tell you to replace O2 sensors without more information. Nothing posted points to an O2 sensor issue. |
#7 |
YOu just bought a used car and don't know jack about it's past maintenance... Plugs are a maintenance item...
#8 |
![]() ![]() ![]() Join Date: Mar 2010
2009 AURA XE
this is definitely one of the possibilities for that eng:
http://www.cartruckinfo.com/engine-m...ough-idle.html |
#9 |
2007 AURA XR
It is a 3.6 so that not the same engine as me. Yeah i didn't know much because it is my Girlfriend car and she bought it from some guy. But he didn't tell us much about it.
I will probably just replace the spark plugs sense that is a regular maintenance item and I know the catalytic converter is going bad but in my county you don't need emissions. But i bypass that but i do not think the Random Misfire is caused from the Catalytic converter. Because if it was the o2 sensor upstream i should get a DTC for the 02 sensor and not Random Misfire i thought. It weird because when i turn the DTC off it will stay off for about a day then come back on. And it runs good so i am not sure. |
#10 |
2009 AURA XE
#11 |
2007 AURA XR
It's werid. I notice it only comes on when the car is hot and when I turn the car off and let it sit for awhile and turn it back one it goes off. Car runs good and kind of idles a little rough
Bookmarks |
'98 SL2 p0300, 0340 | RRK | S-Series Tech | 0 | 03-25-2012 09:16 PM |
p0300 | rj59 | S-Series General | 11 | 02-10-2009 01:49 PM |
96 SL2 with P0300 | wu299 | S-Series Tech | 5 | 07-10-2006 12:15 PM |
P0300 - What to do next? | BarnOwl | S-Series Tech | 7 | 09-14-2005 07:32 AM |
P0300 | Vertigoomg | S-Series Tech | 2 | 08-25-2005 11:51 AM |
