Old 01-26-2022, 08:49 PM   #21
Alberta Pete
Alberta Pete is on a distinguished road
Default Re: 02-05 saturn vue All 4 headlights on?
All you need is one relay. Since the headlights always have power going to them and are turned on by the headlight switch itself making ground.
1. Unplug your high beam connector from the back of the headlight bulb.
2. Shave both wires down to accept a soldered connection.
3. Connect terminal wire 86 to one of the wires and 85 to the other. [It doesn't matter which one) Solder and tape the wires with electrical tape.
4. Unplug your low beam connector from the back of the headlight bulb.
5. Shave down the ground wire for a soldered connection and connect terminal 87 wire. Solder and tape the wire with electrical tape.
6. Connect terminal 30 to ground at body or battery.
7. Reconnect both headlight plugs.
Alberta Pete is offline   Reply With Quote
Old 01-28-2022, 06:18 PM   #22
Cavell
I pulled out the upper core support after accident. I finally drove at night recently and realized lights were out of whack. I wasn’t sure if adjusting screw would even work. It Has never been touched. Seems ok now
saturn headlights saturnsctwo S-Series General 28 11-17-2015 06:25 PM
01-02 Saturn Sc1/2 headlights cdxhizors S-Series General 8 06-20-2014 03:53 PM
Saturn Ion Headlights SaturnIONSLVUE Ion Tech 2 03-09-2009 11:31 PM
HID headlights on a saturn? turbobuick33 S-Series Tech 8 06-09-2008 10:36 PM
Headlights For '94 Saturn Sc1 cargo S-Series Tech 5 09-03-2006 10:51 PM
