Old 11-11-2006, 01:39 PM   #1
djb383
djb383 is on a distinguished road
djb383's Avatar
Default Trailer Towing
Anybody got a tip on how to keep a receiver type hitch from rattling when towing an unloaded trailer? Thanks.
djb383 is offline   Reply With Quote
Old 11-11-2006, 01:51 PM   #2
GearGuy
GearGuy is on a distinguished road
GearGuy's Avatar
Default Re: Trailer Towing
I'll assume that you are using the correct size trailer ball and the trailer coupler is tightened up snug against the trailer ball properly...
If you have some slop in the receiver tube, maybe try wrapping a ring of electrical tape to 'shim' it up and take up the slack? Or is it an in and out slop due to the pin?
2006 Vue 3.5L FWD
GearGuy is offline   Reply With Quote
Old 11-11-2006, 02:06 PM   #3
djb383
djb383's Avatar
Yeah, I've tried the tape and it gets eaten up quickly, then it's back to the rattle. Thanks though. Anybody else? Thanks.
Old 11-11-2006, 02:19 PM   #4
GearGuy
GearGuy's Avatar
Well, I suppose you could step it up and try cutting up a shim out of plastic containers, like a milk jug. Make a sheath that fits into the receiver tube and gets held in place by the pin.
And if it's not durable enough, step up to metal. Home Depot has a selection of metal stock and there is aluminum roof flashing in a roll....
I'm surprised that it's that bad...
What hitch and what drawbar are you using?
Does it pivot on the pin or is it just sloppy in the receiver?
2006 Vue 3.5L FWD
Old 11-11-2006, 02:43 PM   #5
djb383
djb383's Avatar
Thanks again but it's not the hitch or draw bar, it's the trailer, a special purpose motorcycle trailer, that has a very light tounge weight when empty.
Old 11-11-2006, 04:12 PM   #6
mellissam
mellissam will become famous soon enoughmellissam will become famous soon enough
mellissam's Avatar
2006 VUE 2.2L
Maybe try felt stickies....you can get them in Home Depot or most dollar stores...I use them to stop banging cupboard cabinets, but if you put one on each side near the mouth of the receiver, might work. Only costs a dollar or two....
Oh, might try a rubber band! It may not last, but cheap......
'Silven'
K&N / Sheep seats / Run Brds / Roof Rack / Fog Lps / Trailer Hitch / Air Horns / LEDs / Power Inv. / Cool Blues
mellissam is offline   Reply With Quote
Old 11-11-2006, 04:37 PM   #7
djb383
djb383's Avatar
Thanks.
Old 11-11-2006, 09:52 PM   #8
VTchemist
VTchemist's Avatar
When I pull my 5x8 (unloaded), it also makes a lot of noise. When loaded, all is fine.
If you have to pull the trailer (unloaded) is there any place near the front of the trailer and the tongue that you can add some weight? You might could pick up some "barbell" types weights a local thrift shop. Maybe 10 to 25 lbs?
The added weight may quiet the unloaded trailer.
Hope this helps.
Old 11-11-2006, 09:58 PM   #9
djb383
djb383's Avatar
Hey, thanks again.
Old 11-12-2006, 02:15 AM   #10
Venomized
Venomized is on a distinguished road
Venomized's Avatar
etrailer.com has an anti-rattle kit that seems intriguing.
http://www.etrailer.com/mm5/merchant...ategory_Code=L
Otherwise adding weight on the front end of the trailer will work.
06 Vue AWD V6
01 Grand Cherokee
05 Gulfstream Conquest 28 foot class C
Venomized is offline   Reply With Quote
Old 11-12-2006, 01:18 PM   #11
djb383
djb383's Avatar
Dude, thanks a whole bunch for that one!
Trailer Towing with an 08 Vue Warren 2008 Vue 6 09-23-2010 07:34 AM
Relay Trailer Towing Daveak Relay General 9 09-19-2008 07:32 PM
Trailer Towing with an 08 Vue Warren 2008 Vue 1 02-27-2008 02:41 AM
Trailer Towing with an 08 Vue Warren 2008 Vue 5 11-07-2007 06:13 PM
Trailer Towing? born again L-Series General 1 03-13-2005 11:08 AM
