Old 07-06-2010, 10:21 PM   #1
sl2hippie
sl2hippie is on a distinguished road
Default 2005 VUE 2.2 trans question
I apologize for asking another transmission question but I have looked all over this site and many others for the answer to my question but to no avail. So I will ask, What kind of tranny fluid is used for a 2005 VUE with the 2.2 motor? I believe it is the 4 speed not a 5 speed. Where is it drained, and where do you fill it. Thanks for any help!!
Jason
sl2hippie is offline   Reply With Quote
Old 07-06-2010, 10:50 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2005 VUE 2.2 trans question
Jason
Jason ... I have a silly question ... do you have manual or automatic transmission?
If automatic ... check the service parts sticker on latch-side of rear-door on drivers side for one of following RPO numbers MN5, M16 or M75, and repost.
FYI ... RPO for 5-speed manual is MG3.
Old 07-07-2010, 10:08 AM   #3
sl2hippie
UGHH!!! I can't believe I forgot to include that! It's an automatic, FWD. I do have a MN5 number on the sticker. Thanks!
Jason
Old 07-08-2010, 10:11 AM   #4
sl2hippie
please help me out. I need to do this job tomorrow. Thanks.
Old 07-08-2010, 10:51 AM   #5
bestharry
bestharry is on a distinguished road
bestharry's Avatar
2003 VUE 2.2L
Idea Re: 2005 VUE 2.2 trans question
Jason,
As far as I remember, there is a table somwhere in the manual that tells you about the fluids that are used on your Vue. I would check in the meantime is i can get some information for you or others are welcome to chime in.
Harry in Toronto with:
2003 Saturn Vue 2.2 Manual - (Not so) Recent edition
1997 Volvo 850 wagon - Love this Black box (sold)
bestharry is offline   Reply With Quote
Old 07-08-2010, 10:58 AM   #6
far2grumpy
far2grumpy's Avatar
Jason ... a heads up ... it appears you have a 4T45-E Hydra-Matic 4-Speed. There's no service data in the 2005 Vue owners manual for this automatic transmission, but according to the 2007 Vue manual you should service with Dexron - VI ATF.
I'm still looking for absolute confirmation and quantities and will post when found.
I'd read Saturn replaced the VTI on 2005 Vue's with 2.2L with another GM AT but I believe yours is first post I've seen with questions.
Edit added ... the 07 Owners Manual says to change ATF at 100,000 miles for normal service and 50,000 miles severe service (towing, mountains, city traffic at temps greater than 90F).
Do you plan to change your own fluid?
Do you want the procedures to do so?
Old 07-08-2010, 11:23 AM   #7
far2grumpy
far2grumpy's Avatar
I've attached a few extracts from service manual ... note the reference to Dexron III. This fluid is not available in my area so I used Dex VI (Chevy pickup).
I've yet to find change interval for the trans filter - makes sense to do so if its easy to access.
In a rush right now - will post more later - hopefully others will have first hand knowledge of this AT.
Old 07-08-2010, 02:27 PM   #8
sl2hippie
Thank you so much for your help!! It has been really hard to find the right info on this transmission. I think this is all I need. Once again Thank You!!!!! If you find anymore info on this I would greatly appreciate it.
Jason
Old 07-08-2010, 02:48 PM   #9
far2grumpy
far2grumpy's Avatar
Jason
I have one last attachment - a spec sheet which reveals you'll need 6.9 (seven) quarts of ATF.
If you've changed much transmission fluid in your life you'll know you need to drop the pan on most transmissions to get the old fluid out. This little guy is no different, so you'll probably need a new pan gasket, and to do it right, a new filter.
Good luck and let us know how it goes.
2005 L-300 V6 Trans Fluid/Filter change Partymmudasti L-Series Tech 1 03-27-2010 12:08 AM
2005 Vue - Water leaking into manual trans toughschmidt Vue Tech 15 03-10-2010 12:07 AM
New to me 2005 Vue AWD V6 - 1 question! newbievueowner Vue Tech 0 05-04-2008 09:09 PM
2005 Ion 1 question eric3060 Ion General 4 11-20-2007 11:49 PM
2005 3.5l v6 vue exhaust question!? bue05 Vue Tech 8 08-31-2006 03:14 AM
