Old 10-29-2014, 10:10 AM   #1
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Default intermediate shaft bearing replaced
Hey all,
Got some good news. The SKF bearing number that I posted previously is a perfect fit!!! It is in and actually not bad to replace at all. I will post a full step by step set of directions and pics in a few days, but the main things you need are a ratchet, 15 mm socket, flex joint and about two to three feet of extensions!!!!!
Oh yeah, corrosion free Southern parts are a huge help, otherwise expect to use a lot of penetrating oil, a vise, and a hammer to beat the CV axle off the intermediate shaft...
And you have to be careful not to damage the bearing housing/mounting bracket or you will screw your self....and it is aluminum....
Hope this helps....
John
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
lord_varon is offline   Reply With Quote
Old 10-29-2014, 10:18 AM   #2
billysvue
2005 VUE 2.2L
Default Re: intermediate shaft bearing replaced
You're calling out the SKF # here?...........
"........... So, if you go to Napa and order bearing number 6206VSP55 for the price of $28.00, you should be good to go. The specs I have for Napa bearing are: ID 1.1791" OD 2.1653" W .6122". ............"
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 10-29-2014, 11:34 AM   #3
Ikiris
Ikiris is on a distinguished road
Ikiris's Avatar
I purchased my bearing yesterday and having a shot replace it for me on Monday. It is cold and wet here in Southern Ontario and winter approaching rapidly. So I want the job done right by a shop. Thanks again so much for the info you got on this bearing number hunt!
04 Vue 3.5L V6 AWD 297000 km
00 Impala LS 3.8 V6 Loaded 262000 km SOLD
98 SC2 5speed-265000 km SOLD
Ikiris is offline   Reply With Quote
Old 10-29-2014, 04:33 PM   #4
lord_varon
lord_varon's Avatar
2008 VUE 3.6L
Billy,
Yes, the skf number and the naps number are nearly identical, I think that there is a space or dash in there...but is the same thing, and those measurements are right. BUT.. This bearing is only for the 04-07 3.5s as far as I know. I don't think it will work on anything else. Would have to pull a 2.2 intermediate shaft and spec that bearing.
Ikiris,
If you have a garage this job is real easy.... Depending on the CV axle coming off the intermediate shaft. I am actually going to buy a second bearing and new CV axle and have an entire new assembly in stand by.
John...
aka
Lord_Varon
Old 10-29-2014, 05:26 PM   #5
Ikiris
Ikiris's Avatar
Originally Posted by lord_varon View Post
Billy,
Ikiris,
John...
No garage at my house, just a long driveway. Also, I am in Canada and the bearing has been in there for 11 years. 11 years of salt/snow and just Canadian weather. haha So I will let a shop do it this time!
Old 05-31-2015, 12:11 AM   #6
Thacherst
Thacherst is on a distinguished road
Did the replacement work?
I have the same issue now.
Thacherst is offline   Reply With Quote
Old 05-31-2015, 08:37 AM   #7
lord_varon
lord_varon's Avatar
2008 VUE 3.6L
Thacherst,
Actually my problem turned out to be the center support bearing on the rear driveshaft/ prop shaft. So that is the first thing I would replace if I were you.... I had three different mechanics tell me that my center support bearing was good as the rubber around it was nice and soft and pliable, no movement in the bearing.. All signs good. I swapped out intermediate shaft bearing and still had noise.... Swapped out center support bearing and silence. A good check is to drop rear driveshaft and then take car for a spin. if no noise then center support bearing.... If still noisy... Intermediate shaft bearing.
And my write up for doing the intermediate bearing is pretty good if that is the problem.
Let me know if you need any help.
John
aka
Lord_Varon
Old 04-29-2017, 05:21 PM   #8
psniadecki
psniadecki is on a distinguished road
1991 SL1
2002 VUE 2.2L
Default Re: intermediate shaft bearing replaced VUE 2004
Please help.... can't find an after market bearing to replace the Intermediate Shaft Bearing for a 2004 VUE with FWD CVT Tranny. The GM DEALER says the part is no longer stocked.
Also, has anyone tried an alternate GM part number to see if it will be a replacement?
Paul
1991 SL1
2004 2.2 VUE, VTI
2002 2.2 VUE, Manual
2003 2.2 VUE, VTI(tranny failure at 112K miles)
psniadecki is offline   Reply With Quote
Old 05-31-2017, 03:06 PM   #9
lord_varon
lord_varon's Avatar
2008 VUE 3.6L
psniadecki,
I would just hit up local junkyards for a used one. Then when you have the one out, get the measurements for the bearing, and a part number, and see if you can rebuild the piece with a new bearing... That is what I ended up doing.
John
aka
Lord_Varon
Old 05-31-2017, 03:48 PM   #10
waiter21
2003 VUE 2.2L
Try these two part numbers:
6206VSP55
and
539860-R20-28
This bearing is also used on a 2000 Cadillac Catera 3.0L V6
It looks like Rock Auto has one in stock.
This is NOT an standard 6206 bearing. its 55 mm wide, thats what makes it wierd.
Old 12-26-2019, 12:04 PM   #11
jeopardy98
jeopardy98 has a spectacular aura aboutjeopardy98 has a spectacular aura aboutjeopardy98 has a spectacular aura about
I just wanted to follow up for anyone that stumbles across this thread. I have an 04 FWD 2.2 manual and the bearing numbers in this thread are correct. Not a hard job at all. It took me about 2 hours working in a messy shop but I did have access to a lift. No more clunk!
'07 ION 2
'05 Malibu Maxx
1987 Dodge Dakota
1996 Jetta GLS
'04 Suzuki SV650
1985 Honda ATC250SX
jeopardy98 is offline   Reply With Quote
Old 03-19-2021, 05:55 PM   #12
ben1989
ben1989 is on a distinguished road
Following up in case anyone is looking for an earlier model - NAPA Part 6206VSP55 fitted in my 2003 Saturn Vue 2.2l FWD Manual.
ben1989 is offline   Reply With Quote
Old 04-22-2021, 05:44 PM   #13
pandkd
pandkd is on a distinguished road
2004 VUE Red Line
1997 SC2
Has anyone checked to see if the shaft off of a Honda Odyssey would work?
pandkd is offline   Reply With Quote
2006 Vue intermediate shaft bearing problem Woodworker Vue Tech 12 08-18-2016 10:02 AM
Half-shaft stuck in intermediate shaft out of car Rivernut Vue Tech 1 01-20-2013 05:20 PM
Intermediate Steering Shaft replaced, again. AuraDrvr89 Aura General 11 11-23-2012 04:09 PM
Intermediate Shaft ? todd8 S-Series Tech 16 02-08-2011 03:26 PM
Intermediate Shaft Bearing Wobble jdcart S-Series Tech 0 10-29-2006 09:36 PM
