Old 02-21-2021, 09:54 AM   #1
Berettadan
Berettadan is on a distinguished road
Default 2005 trans
I just purchased a 05 sedan with a auto trans has a 2.2 in it. I found a 06 trans that was matted to a 2.4 for sale local. Question is it the same trans from my research 05 and on had the same trans but wanted to make sure with you guys. Can't find a definite answer thanks
Berettadan is offline   Reply With Quote
Old 02-21-2021, 10:14 AM   #2
Berettadan
Default Re: 2005 trans
Trans is bad in the car
Old 02-21-2021, 10:56 AM   #3
Bill Murray
2007 ION-2 Quad Coupe
1997 SC1
Over its model life the Ion used the ill-fated GM CVT, a capable Aisin 5-speed, and the GM 4T40/45 which was also a solid unit produced in the millions so it will be supported in the aftermarket for decades.
I believe all 2005 and up used the 4T40/45 and your example should interchange OK.
FWIW there's a feed tube in this trans that sometimes cracks causing loss of drive in forward but it's a pretty easy repair.
Old 02-21-2021, 11:20 AM   #4
Berettadan
Ok I'll look into that thanks
Another 2005 Trans Problem JoeSo Ion Tech 6 08-06-2016 12:58 AM
Trans fluid change on 2005 3.5L PTAaron1 Vue Tech 17 04-03-2014 01:25 PM
2005 VUE 2.2 trans question sl2hippie Vue Tech 8 07-08-2010 02:48 PM
2005 L-300 V6 Trans Fluid/Filter change Partymmudasti L-Series Tech 1 03-27-2010 12:08 AM
2005 Vue - Water leaking into manual trans toughschmidt Vue Tech 15 03-10-2010 12:07 AM
