Old 04-11-2017, 12:43 PM   #1
mangler66
mangler66 is on a distinguished road
mangler66's Avatar
2007 VUE 2.2L
Default New lowering springs : is there any rubber part I should also replace?
Well after 10 years in the salt my Eibachs have had it, and I ordered some new Megan springs. My question is what do people usually replace at the same time? I found a rear lower lower rubber isolator and definitely changing those, but what about the upper? Should I be changing the bump stop? Fronts look OK still, and strut bearings are still good, so I think I'm OK in the front.
2.2L 5 speed, Eibach springs, Centerforce Df clutch, OBX LSD, ES poly sway bar bushings
mangler66 is offline   Reply With Quote
Old 05-12-2017, 09:21 PM   #2
mangler66
mangler66's Avatar
2007 VUE 2.2L
Default Re: New lowering springs : is there any rubber part I should also replace?
For those who are wondering the K160073 rear coil spring isolators from Moog fit like a glove on the Megan springs. I installed 4 of them and they fit just as well on the top and bottom of the springs.
Old 05-12-2017, 11:26 PM   #3
billysvue
2005 VUE 2.2L
Smart, Mine were almost shot when I installed my Megan's.
Change out your SB bushings, too? Easy swap at most any 4x4 shop with a generic size selection of Energy Suspension polybushings with mating strap/mount( get with zerks).
Then there's the SB end links... after that, you shouldn't have many more loose bits besides shocks and struts, suspension rubber bushings/Bjoints ,as they age.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 05-13-2017, 07:57 PM   #4
mangler66
mangler66's Avatar
2007 VUE 2.2L
Yep, I have ES rear sway bar bushings already, that I modified to be greasable (added a groove inside, a hole and a zerk fitting). Not as good as the fronts, that are factory greasable ES bushings, but better than nothing. They warn me when I need an oil change, they usually start to squeak after 10000 km without a greasing
Old 02-26-2021, 10:13 PM   #5
New2meVue
New2meVue is on a distinguished road
2007 VUE 2.2L
How much did the springs lower the car?
New2meVue is offline   Reply With Quote
Old 03-01-2021, 10:19 AM   #6
dads toy
dads toy is on a distinguished road
I am trying to find lowering springs and shocks already put together for the front. I also want to lower the rear at the same time. does anyone know where I can get a set of matching shocks and springs.
dads toy is offline   Reply With Quote
need to replace front coil springs/replace struts too? dapper S-Series Tech 24 05-13-2015 02:42 PM
lowering springs sw2 kid S-Series Mods 6 04-15-2008 10:42 PM
lowering springs sw2 kid S-Series Mods 4 04-13-2008 05:59 PM
Lowering Springs Sl1tech S-Series General 4 09-25-2005 10:31 AM
