Old 09-04-2021, 06:46 PM   #1
RICH1959
RICH1959 is on a distinguished road
Default Transmission problem
working on a 99 sw2 automatic the trans shifts fine but when it warms up and gets hot the trans starts shifting hard and then acts like it will not shift out of low gear
RICH1959 is offline   Reply With Quote
Old 09-04-2021, 06:53 PM   #2
billr
Default Re: Transmission problem
Is this vehicle new to you, with unknown history? If so, I would start by checking LP to see if there is an obvious problem there (after checking fluid level, of course). If LP is OK, then change fluid and filter and see if that helps. Use only Dex3/Mercon fluid, no Dex6.
If getting known-good fluid in there doesn't help, then this is probably going to end up needing the valve-body replaced.
Do you have access to trans live-data? That would help to eliminate other problems before throwing a VB at it.
Acceleration problem...gets stuck...possibly transmission? Or a gas problem? Dingo Warrior S-Series General 34 03-29-2009 01:20 PM
Transmission problem Daredevil6534 S-Series General 2 02-05-2009 12:35 AM
Maybe Transmission Problem... tk3000 S-Series General 0 01-06-2009 03:57 AM
transmission problem? twobassers Ion General 1 02-28-2006 09:26 AM
is this a transmission problem??? madhattr88 L-Series General 14 07-15-2005 09:51 AM
