Old 12-20-2011, 08:48 AM   #1
ghoulie27
ghoulie27 is on a distinguished road
Default forward gear slamming only after re-learning
I have an interesting problem. I have a 1997 SW2 and have had the hard shifting/slamming problem in my forward gears. I have tried the Wolfman cure, replaced the valve body with a rebuilt, input and output shaft nuts are tight, TPS replaced, valve body and EGR cleaned. When I disconnect the battery, the shifting is smooth for the first half-hour of driving. After that, when I take it out the slamming starts. I drive 30 minutes to work so in theory I could disconnect/connect the battery at home and at work, but that seems needless. Any suggestions would be lovely.
ghoulie27 is offline   Reply With Quote
Old 12-20-2011, 11:02 AM   #2
Default Re: forward gear slamming only after re-learning
Is there any chance you're still using the original round nosed plastic coolant sensor?
Old 12-20-2011, 06:13 PM   #3
ghoulie27
I will check. Here is an update. Today I drove it for 30 minutes with no problems after having the positive to the battery disconnected for two days. Disconnected the positive, let sit for 6 hours, and drove home. The slamming returned immediately.
Old 12-20-2011, 07:16 PM   #4
Every time you disconnect the battery or pull the PCM B fuse you reset the learned shifting patterns. It takes about an hour of gentle driving around residential neighborhoods where you **** up through all gears and allow the transmission to downshift through all gears as you come to a stop. No full throttle driving. Once learned do not be disconnecting the battery or pulling the PCM B fuse or you get to do this all over again.
Tags
re-learn, shifting hard, slamming, transmission
96 SL1 Trans Issue, Goes forward in neutral and reverse? No First gear either? Jetski1963 S-Series Tech 0 03-03-2011 12:30 PM
4th gear slamming like a mo! saturn97sl1 S-Series Tech 1 01-06-2011 04:09 PM
Slamming duriung gear shifts mad_nigerian S-Series General 7 04-06-2006 12:11 PM
1991 SL2, engine slamming into firewall when put into gear Kielvec S-Series Tech 31 02-17-2006 07:16 PM
99 SC2 in Reverse Gear Going Forward?? Latent S-Series Tech 2 11-24-2005 10:26 PM
