Old 04-08-2011, 03:37 PM   #1
laribel
laribel is on a distinguished road
1996 SL1
1997 SL
Default ignition test vs. CPS test for no start troubleshooting
If I have tested the plug wires with an ignition tester in place of spark plug grounded to the engine (and there was spark), is there a need to test the CPS as in richpins video by observing arc on coil pack? Or would doing so be basically testing the same thing?
If spark goes through the plug wires, it has to be going through the coil pack, right?
laribel is offline   Reply With Quote
Old 04-08-2011, 04:47 PM   #2
Default Re: ignition test vs. CPS test for no start troubleshooting
If you mean those inexpensive spark testers that don't require removing the plugs and using the internal gap between electrodes to act as a spark plug then yes you're testing for spark. A successful spark test for any plug already confirms an operating cps but not completely. This can be taken out of context by asking only a focused question. What you haven't done is test for when the engine is fully warmed up and spark is lost unless you performed two spark tests, one with a cold engine and after the engine dies at random and conduct another spark test right at that moment when the engine cannot be restarted. Testing for spark encompasses the entire EFI system including failure with a fully warmed up engine or at anytime when the engine fails to start. Just don't assume a cold engine test is all that's needed.
Old 08-30-2021, 02:14 PM   #3
billr
Wherever you check for spark is OK to see if CKP signal is good.
What problem are you trying to solve; is the engine refusing to start, or keep running, or runs poorly at times? As said above, you have to check things when the problem pops up.
Old 08-30-2021, 02:45 PM   #4
Waiex191
Waiex191's Avatar
billr, the problem that spambot is trying to solve is to get you or anybody to click the link embedded in its fake post. Note the subtle signs:
1) It is responding to a decade old post
2) It has spelling worse than most (but not all!) of our members.
3) It makes slight changes to old posts and tries to repost them to make them seem like a real person, like:
original:
spambot:
On the off chance that sparkle goes through the fitting wires, it must be going through the loop pack, correct?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
OBDII failed self test smog test failed craigar S-Series Tech 23 08-21-2017 04:46 PM
Battery, Starting and Charging Systems test okay at Autozone, now car won't start jacarolan S-Series Tech 17 04-08-2011 12:27 PM
how do i test ignition switch wires yerds41 S-Series Tech 0 11-27-2010 07:40 PM
02 SL1 Doesnt Start-Troubleshooting to date rob0225 S-Series Tech 7 09-24-2010 08:39 PM
How do I test the ignition switch? autiger S-Series Tech 5 03-22-2009 12:09 PM
